I had to bump up the contrast +2 on my 7D to match my XSi
garycoleman Senior Member 450 posts Likes: 12 Joined Aug 2008 Location: California More info | Oct 30, 2009 20:03 | #1 I had to bump up the contrast +2 on my 7D to match my XSi Canon 5D MKIII | Canon 60D | 24-70mm f/2.8L II | 17-55mm f/2.8 IS | 70-200mm f/2.8L IS | 580EX II
jwcdds Cream of the Crop More info | Oct 30, 2009 20:05 | #2 Another way of viewing this might be that the XSi has less dynamic range than the 7D? Julian
binlerne Senior Member 870 posts Joined Feb 2008 Location: San Diego, CA More info | Oct 30, 2009 20:25 | #3 |
garycoleman THREAD STARTER Senior Member 450 posts Likes: 12 Joined Aug 2008 Location: California More info | Oct 30, 2009 20:37 | #4 binlerne wrote in post #8927205 Gotta ask, same lens? same settings? Same exposure? of course. same lens (17-50), focal length, aperture, iso. Canon 5D MKIII | Canon 60D | 24-70mm f/2.8L II | 17-55mm f/2.8 IS | 70-200mm f/2.8L IS | 580EX II
stsva Cream of the Crop More info | Oct 30, 2009 20:39 | #5 garycoleman wrote in post #8927260 of course. same lens (17-50), focal length, aperture, iso. Same scene and lighting? Some Canon stuff and a little bit of Yongnuo.
Oct 30, 2009 20:42 | #6 garycoleman wrote in post #8927260 of course. same lens (17-50), focal length, aperture, iso. RAW and JPEG? My Canon kit 450D/s90; Canon lenses 18-55 IS, 70-210/3.5-4.5....Nikon kit: D610; 28-105/3.5-4.5, 75-300/4.5-5.6 AF, 50/1.8D Nikkors, Tamron 80-210; MF Nikkors: 50/2K, 50/1.4 AI-S, 50/1.8 SeriesE, 60/2.8 Micro Nikkor (AF locked), 85mm/1.8K-AI, 105/2.5 AIS/P.C, 135/2.8K/Q.C, 180/2.8 ED, 200/4Q/AIS, 300/4.5H-AI, ++ Tamron 70-210/3.8-4, Vivitar/Kiron 28/2, ser.1 70-210/3.5, ser.1 28-90; Vivitar/Komine and Samyang 28/2.8; 35mm Nikon F/FM/FE2, Rebel 2K...HTC RE UWA camera
DBJ Senior Member 326 posts Joined Jan 2009 More info | Oct 30, 2009 20:46 | #7 Same picture styles? Does XSi have picture styles? 7D | 500D | 350D || 11-16mm 2.8 | 15-85mm IS | 17-55mm 2.8 IS | 24-70mm 2.8L | 24-105mm 4L IS | 70-200mm 2.8L | 70-200mm 4L IS | 30mm 1.4 | 50mm 1.4 | 85mm 1.8 | 135mm 2L || 18-55mm | 18-55mm IS | 100-300mm | 50mm 1.4 nikkor | 50mm 2.5 || 580EX II | 430EX II x2
garycoleman THREAD STARTER Senior Member 450 posts Likes: 12 Joined Aug 2008 Location: California More info | Oct 30, 2009 21:07 | #8 stsva wrote in post #8927266 Same scene and lighting? yes. I swapped lenses between bodies right on the spot. kitacanon wrote in post #8927276 RAW and JPEG? raw DBJ wrote in post #8927297 Same picture styles? Does XSi have picture styles? xsi has it. used xsi standard picture style with contrast of 0 Canon 5D MKIII | Canon 60D | 24-70mm f/2.8L II | 17-55mm f/2.8 IS | 70-200mm f/2.8L IS | 580EX II
RDKirk Adorama says I'm "packed." More info | Canon has documented that contrast, saturation, and sharpness controls on its cameras decrease in incremental value as the level of the cameras increase. The P&S cameras have the greatest amount of bump-per-control-increment, the 1-Series cameras have the least. Also, the "neutral" position (which isn't truly neutral) starts out more contrasty, saturated, and with more sharpness on the lower-end cameras than the higher-end cameras. TANSTAAFL--The Only Unbreakable Rule in Photography
CYO Member 43 posts Joined Oct 2009 More info | Oct 31, 2009 00:03 | #10 XSI's image quality is surprisingly good comparable to the more expensive xxd, 7d.
jwcdds Cream of the Crop More info | Oct 31, 2009 00:07 | #11 It's an APS-C Canon CMOS sensor. It's been great since what.. the 20D? But if you want to strip away everything else about the 7D (build, new/better AF, 100% VF, wireless flash controller, MFA, HD video, etc...) and then yeah, the 7D's IQ seems a little bit overpriced. Julian
krb Cream of the Crop 8,818 posts Likes: 8 Joined Jun 2008 Location: Where southern efficiency and northern charm come together More info | Oct 31, 2009 00:15 | #12 CYO wrote in post #8928049 XSI's image quality is surprisingly good comparable to the more expensive xxd, 7d. The Rebels have always had IQ similar to their larger siblings. When you go from a Rebel to an xxD you are getting better build quality, better ergonomics, faster AF, higher frames per second, etc. These things don't do anything to increase the IQ that the lens is capable of but they do make it much easier for the photographer to get as much of that IQ as possible under a wide variety of conditions. -- Ken
Oct 31, 2009 00:57 | #13 I have to say all these threads are not giving me much faith in the 7D. Canon eos 7d
jwcdds Cream of the Crop More info | Oct 31, 2009 01:14 | #14 kensei wrote in post #8928184 I have to say all these threads are not giving me much faith in the 7D.
Julian
FlyingPhotog Cream of the "Prop" 57,560 posts Likes: 178 Joined May 2007 Location: Probably Chasing Aircraft More info | Oct 31, 2009 01:15 | #15 Of course it isn't... Jay
| Latest registered member is zachary24 1447 guests, 149 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
