Thread started 31 Oct 2009 (Saturday) 18:02
Question from studio flash newbie
KevinA
Oct 31, 2009 18:02 |  #1
Can someone tell me what auto dump is please.
Cheers
5D Mk3 | Canon 85mm 1.2 ll L | Canon 100mm 2.8 L Macro IS | Canon 135mm 2.0 L | 4 X EX600 RT Speedlites | ST E3 RT Transmitter PLUS... Fuji XT-2, Fuji X-Pro 2, 10-24mm 14mm, 23mm 35mm, 56mm 90mm, 50-140mm & 100-400mm lens... and a selection of Pocketwizard flash triggers
www.ahronson.com (external link)
jeromego
Oct 31, 2009 18:06 |  #2
KevinA wrote in post #8931453 (external link)
Cheers
its when you stop down the power of the strobe....it dumps the previous power setting you had on. I'm sure someone can explain this better in a more technical way. but that's basically what it is.
Jerome
Canon CPS Member
www.lightsandimages.co​m (external link)
facebook (external link)
Curtis ­ N
Master Flasher
Oct 31, 2009 18:10 |  #3
The strobe will fill its capacitors with the amount of energy you have it set to. Traditionally, if you lowered the setting, you needed to fire the strobe once to "dump" that charge so it could recycle to your new, lower setting. Otherwise, the first shot at that setting would give you too much light.
With auto dump, it releases that energy automatically so you don't have to fire the strobe after you lower the power setting.
ootsk
Joined Jan 2002
Oct 31, 2009 19:34 |  #4
Curtis N wrote in post #8931490 (external link)
Great explanation, but I still fire it once after I lower the setting because I just do.
Curtis ­ N
Master Flasher
Oct 31, 2009 19:39 |  #5
So do I, because I've found the auto dump on the Alienbees doesn't quite get it right.
KevinA
Nov 01, 2009 09:08 as a reply to  @ Curtis N's post |  #6
Thanks guys - it all makes sense now.
I've just ordered my first set of strobes - which have this feature.
The mystery is now solved
1,388 views & 0 likes for this thread, 4 members have posted to it.
1055 guests, 115 members online
