On a 50D with an old 420EX Flash (which is E-TTL), I am not seeing the expected behavior when shooting in Av-priority mode.
As I understand it, in Av-priority I should be able to set the aperture, and the camera will choose a speed between 1/30 and 1/x (1/x is the maximum flash sync speed) and adjust the flash output accordingly.
But when I shoot in Av-priority; it is setting ridiculously slow shutter speeds (like one half second).
Here are two pictures I took the other night; everything is the same except one was taken in Av-priority and the other in Program mode.
What have I done to allow the camera to choose such a long shutter speed in Av-priority? (I have left the EXIF info in tact. These are right off of the camera, converted to JPEG with DPP and cropped with ACDSee)
| HTTP response: NOT FOUND | MIME changed to 'image/gif' | Redirected to error image by FLICKR |
| HTTP response: 404 | Byte size: ZERO |
