Thread started 06 Nov 2009 (Friday) 07:45
What Color Temperature to use when Calibrating Monitors?
John ­ E
Nov 06, 2009 07:45 |  #1
I use the Spyder 3 Pro for my monitor calibration. Initially, it asks me what white balance I want to use. I've tried: 2.2 5000K, 2.2 5800K, and 2.2 6500K. 5000K is my favorite as the others appear too bluish on my monitor. The room with is lit with mostly yellow incandescent light. (I have a HP2408H monitor with Windows 7, 64-bit, Lightroom, Photoshop CS4)
My questions are:
1) What is the best white balance temperature to use or is this personal preference?
2) Does this ultimately effect setting the white balance in an actual photo (using the white eye dropper)? In other words, if I have the monitor set to 2.2 6500K will this make the photo more blue than a 5000K white balance?
Thanks for your advice?
John Elser
Canon 5D MK II; 30D; EF 85 f/1.8; EF 70-200L f/2.8 IS II; EF 24-105L f/4; EF 135L f/2; EF 24-70L; Canon 580 EX II(x3).
Electric ­ Shepherd
Nov 06, 2009 07:57 |  #2
Generally speaking you want a gamma of 2.2 and a temp of 6500K.
As regards the image looking too blue, that may simply be a question of your eyes readapting and it may seem unnatural for a while.
How do your prints compare to your screen?
My flickr (external link)
Nouks
Nov 06, 2009 08:09 |  #3
Native or 6500K. If one really fails, try the other and see if that gives better (more neutral) results.
I used to be Gebruikersnaam.
Gearlist: 1D2, resurrected 20D, 400D, 16-35L, 28-70L, 70-200L, 85 F1.8, cute 18-55, dead 24-70 Siggie, 2 flashlights, expensive bags and loads of CF-cards.
Website (external link)Portfolio (external link)Archive (external link)
bwolford
Nov 06, 2009 08:10 |  #4
Electric Shepherd wrote in post #8965653 (external link)
This is precisely why I went with the Huey, it adapts to ambient light.
+1 for your eyes adapting to the adjusted calibration. Mine felt awful, but prnt quality was significantly better after I became accustomed to the adjusted monitor. All skin tones were more accurate as well as saturation and contrast. Best thing I ever did. Calibrate, process a few images and have them printed. You'll like the result.
Brice
Sample Gallery (external link)http://thewolfords.com​/2007XmasProofs (external link)
ChasP505
"brain damaged old guy"
Nov 06, 2009 08:11 |  #5
Here's some info which may help you. I would stay with with settings of 6500k or native in your calibration software and 2.2 gamma.
http://www.prad.de …view-hp-w2408h-part8.html (external link)
Yes, the incandescent lighting will affect your color perception. At barest minimum get a low wattage CFL bulb at 4700-5000k and don't have it throwing light on the screen.
Chas P
Lowner
"I'm the original idiot"
Nov 06, 2009 11:18 |  #6
I use 6500 deg K.
Richard
limwhow
Joined Sep 2009
Nov 06, 2009 11:30 as a reply to  @ Lowner's post |  #7
I set mine to gamma 2.2 at 5000K.
A professional photobook printing company advised me to use 5000K if my ultimate aim is to print my pictures using a professional lab service.
In addition, I have been advised to set it to 6500K if I were to print on my own using inkjet printers.
Anyone of you have the same kind of advice?
With Humility I come. Canon.
With pictures I record Life & Love.
1DsMkIII | 1DMkIV [COLOR=RoyalBlue]| 20D R72 IR-modified
Electric ­ Shepherd
Nov 06, 2009 11:53 as a reply to  @ limwhow's post |  #8
That may make a lot of sense if you're planning on viewing prints under a 5000K illuminant [quite typical], but anything posted to the web may have a colour cast if edited under these settings. Better in these circumstances to soft proof your prints using a printer profile calibrated to 5000K but your monitor set to 6500K still.
limwhow
Joined Sep 2009
Nov 06, 2009 12:02 |  #9
Electric Shepherd wrote in post #8967120 (external link)
Electric Shepherd, thanks for your feedback. Will certainly look into it.
John ­ E
Nov 06, 2009 12:30 |  #10
Thanks for all your feedback. I'll try 6500K for a while -- but it sure is hard getting used to after having it set to 5000K for so long.
John Elser
5,663 views & 0 likes for this thread, 7 members have posted to it.
499 guests, 126 members online
