Thread started 06 Nov 2009 (Friday) 09:29
Looking for opinions on Cokin system for three 77mm lenses.
Agged
Nov 06, 2009 09:29 |  #1
I'm going to buy a some ND and Graduated filters, and will be using them on my 10-22, 24-105L and 70-200 2.8 IS lenses.
I'm getting the impression that the Cokin P system doesn't work particularly well with the 10-22 or the 70-200. Is that so?
Should I stick with glass filters or perhaps go with the Cokin Pro-Z system?
I'm seeking any real world experience that anyone has.
Will shoot anything that catches my eye. Particularly drawn to anything on or near water. Still trying to find my photographic niche!
Canon 6D / 7D Mark II / G9 X Mark II / Sony α6000 / Samsung S22 Ultra
stargazer77517
Nov 06, 2009 09:33 |  #2
Go with the Z-Pro, I have the 10-22mm canon and the Lee setup. the Z-Pro is the same size as Lee, you wont have any problems. I use the resin ones instead of glass. Just a preference thing I guess.
Davis (Fred)
My Gallery http://davisbourque.ze​nfolio.com/ (external link)
wimg
Nov 06, 2009 09:45 |  #3
Agged wrote in post #8966166 (external link)
I was in a similar position a while ago, and went for the Z-Pro system.
Works well on 10-22 on APS-C and/or 17-40L on FF, f.e..
I like the fact that you can add extra filter holders to the Z-Pro, or use fewer, in case you need that. Furthermore, Cokin also supplies a (glass) CP for use with the Z-Pro filter holder, which, unlike the Lee f.e., can be positioned very closely to the lens, and can rotate independently of the remainder of the filter stack.
HTH, kind regards, Wim
dustyporch
Nov 06, 2009 10:53 |  #4
I have a Sigma 10-20 instead of the 10-22, but I use the Cokin P system with a Wide-holder, instead of the standard one. It works just fine without any vignetting. The downside is that you only get a CPL and one square filter in it, but that's fine for my needs.
My photos on Flickr... (external link)
g3org3y
Nov 06, 2009 11:03 |  #5
I am tempted by the Z-Pro but it is A LOT more expensive than the P Series.
@Dusty - No vignetting at all, even at 10mm? Sounds promising.
EOS 400D, Sigma 10-20, Tamron 17 -50, Nifty Fifty f/1.8, Canon 100 f/2, 70-200L f/4, Speedlite 430EX II.
Tapeman
Sliced Bread
Joined Jan 2004
Nov 06, 2009 16:01 |  #6
I use the P series on 77 mm lenses, no problems.
Canon G1X II, 1D MKIV, 5DSR, 5DIV, 5D MKII, 16-35/2.8L II, 24-70/2.8L II, 70-200/2.8L IS II, IS, 100-400/4.5-5.6 L IS II, 500/4 L IS II, 24-105/4 IS, 50/2.5 macro, 1.4x MKII, 1.4X MKIII, 2X MKIII,580EX II, 550EXs(2), ST-E2.
Gitzo 1228, 1275, 1558, Lensbaby 3G. Epson 3880, Bags that match my shoes.:)
Agged
Nov 06, 2009 16:04 |  #7
Tapeman wrote in post #8968609 (external link)
Tapeman, looking at your gear list, you are just the guy I want to talk to.
How does the 77 mm P series work on your 24-105 L and 70-200 2.8 IS?
Would using the 77mm on the FF 16-35 FF yield the same good result on the crop EF-S 10-22?
1,090 views & 0 likes for this thread, 6 members have posted to it.
1347 guests, 184 members online
