Thanks for the great effort. It is well done and I can tell that a lot of work went into the project. The review help to clarify a couple fine points that I had not investigated yet such as the information about the +/- 5 stops of EC.
The only qualm that I would have relates to the image sharpness comparison between the 7D and 5D Mark II. Although it appears that many, if not most, people subscribe to the multiplication factor argument about smaller sensors, I feel that the "multipliplication factor" is based on some shaky assumptions such as printing all image on the same size paper. In any case, however, comparing sharpness of sensors of different size and photodiode density results in a situation like trying to compare apples and oranges so I won't criticize your effort towards being equitable -- it is somewhat of a "no-win" situation if trying to please everybody.
If I were to try to make a comparison (which I won't do), I would have ignored the sensor size and then normalized photodiode density in equal sized areas of the two sensors. Since the 5D has a lower photodiode density than the 7D, that means that I would have scaled down the 7D so that a monitor screen pixel represents the same area for both sensors. I am just speculating, but I have a definite feeling that doing things this way would reveal that there is very little or no difference to be found. Image sharpness is primarily a lens function and secondly it is a function of the demosaicing algorithm which should inherently handle the slight loss of sharpness introduced by the anti aliasing filter.
