Thread started 06 Nov 2009 (Friday) 14:06
ef-s on ef mount?
footballdude2k3
Nov 06, 2009 14:06 |  #1
If all that is really different is that the back sticks out a bit more, would you be able to use say kenko extention tubes an have a 17-55 work on a 5d2?
footballdude2k3
Nov 06, 2009 14:09 |  #2
if you are able to do this, would you lose a stop?
gjl711
Nov 06, 2009 14:11 |  #3
You would loose some light depending on the tube used. You would also loos the ability to focus at distance again depending on the tube used. Why do you want to do this?
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
footballdude2k3
Nov 06, 2009 14:12 |  #4
oh i dont want to do this, my mind is usually 8 places at once, so it was just a random thought, if i were to think about doing this i would prolly sell a 17-55 and pick up a 24-70.
gjl711
Nov 06, 2009 14:14 |  #5
footballdude2k3 wrote in post #8968034 (external link)
That would be best. The 24-70 on a full frame is about as perfect as the 17-55 on a crop.
::Gear::
thegrandpoohbah
Nov 06, 2009 14:14 |  #6
It would probably work for macro shots but you lose the ability to focus to infinity so the lens won't really "work".
Canon EOS 6D | Canon Powershot S95 w/ WP-DC38 | Rokinon 14mm f/2.8 IF ED UMC | Canon EF 24-105mm f/4L IS USM | Canon EF 100mm f/2.8 Macro USM | Canon EF 70-200mm f/2.8L IS II USM | Kenko Teleplus Pro 300 1.4X | Canon Extender EF 2X III | Canon Speedlite 580EX II | Sigma EF 530 DG Super | Flickr (external link)
XsiBrian
Nov 06, 2009 15:15 as a reply to  @ thegrandpoohbah's post |  #7
I tried this when I first got my Kenko Tubes (for fun) and while it works with a 12mm tube >~35mm, the shorter focal lengths can only focus inside the lens (Negative working distance). At 55mm the infinity focus is around 6-8" and if I recall correctly the corners were very much black. There is little real use for this setup beyond curiosity.
footballdude2k3
Nov 06, 2009 15:37 |  #8
XsiBrian wrote in post #8968380 (external link)
sounds good, thank you sir.
racketman
Gallery: 20 photos
Nov 06, 2009 16:11 |  #9
I've played with 60efs on a tube mounted on a 1DMKIII and works well as a macro lens with focus range from about 3" in front of the lens at 1:1 to 13" at 00. With the Canon 12 tube you keep AF.
Toby
DreDaze
Gallery: 49 photos
Nov 06, 2009 19:16 |  #10
footballdude2k3 wrote in post #8967999 (external link)
the difference isn't just the mount...there's also the smaller image circle...so there will be a lot of vignetting...
Andre or Dre
gear list
Instagram (external link)
Canon ­ Bob
Nov 07, 2009 06:59 |  #11
DreDaze wrote in post #8969524 (external link)
Not forgetting that as the lens is moved away from the sensor (by the tube) then the image circle will become larger....exactly why extension tubes result in greater magnification.
Bob
1Dx2 (2), 5DSR, 1Ds3, 1D4, 5D2(590nm), 5D2(720nm) EF600 EF400 EF300-II EF300 EF200 EF200-II EF180L EF135L EF100 EF85-II EF50L TS-E17/4 TS-E24L-II TS-E45 TS-E90 MP-E65 EF70-200-II EF24-70/2.8-II EF16-35/4 EF8-15/4 EF11-24/4 Zeiss 15/2.8 21/2.8 25/2 28/2 35/1.4 35/2 50/2 85/1.4 100/2 135/2 T/C's L-SC & a WIFE!
1,198 views & 0 likes for this thread, 7 members have posted to it.
ef-s on ef mount?
679 guests, 126 members online
