Thread started 08 Nov 2009 (Sunday) 07:51
What matters for low-res product shots?
Nareg
Nov 08, 2009 07:51 |  #1
Hello all, I own a website where I sell arcade parts.
Naturally, there is a need for product shots for each of the 250 items I stock... but I'm really not satisfied with the way photos have turned out with my equipment.
Here's the situation:
Most of the products are less than 4 cubic inches in size (2x2x2)
I'm taking all of my photos on a macro setting with a consumer grade digital camera.
I don't have a light box, but I understand I might need to get one for better diffusion.
Generally, my complaint is in FOCUS. I want to get a new camera that can actually focus on these small products and come out with good pictures. The photos all end up being scaled down to web-shots of 350x230 pixels, so if I understand megapixels correctly, they shouldn't really matter for my work?
I guess what i'm asking is, what's a good camera for macro shots. If i can save money by getting a camera with a LOW megapixel count, I would like to do that, since it seems to me that for my applications, only the lens really matters.
katodog
Nov 08, 2009 08:00 |  #2
For what you're doing, get a piece or two of white poster board and a few LED flashlights. Put a sheet of poster board under the product, and one behind the product. Shine the LED flashlights at the product at an angle. If need be, you can diffuse the lights with a sheet of white paper, just wrap the paper around the front of the light and tape it in place. Experiment for a few minutes to get the right lighting and start shooting.
Fast, cheap, easy...poster board and lights. Put your camera on a tripod and use the timer if it has one. Keeps the shakes down and makes the image sharper. For little parts like the button you showed, the sharper the better. Showing clarity in product photos is what sells the product.
What kind of camera are you currently using?
The only stupid question is the one that goes unasked - Photographers shoot to thrill, not to kill
My Gear- Flickr (external link) - Facebook (external link) - Smoke Photography - - Sound-Activated Paint
alessandro2009
Nov 08, 2009 08:14 |  #3
Nareg wrote in post #8976470 (external link)
See the specifications of your compact camera about the minimum distance.
Put a little more distance and eventually do a small crop.
Nareg
Nov 08, 2009 10:51 |  #4
My camera is a Konica Minolta DiMage G600.
I have a newer camera which is a casio exilim, but this minolta seems to take better pictures up close.
Still, i'm not really happy with it. Could it have something to do with the shutter speed?
I take all of my shots with an extremely steady hand, and i make sure to allow the camera to focus before full depression on the button, yet still, many pictures do not come out focused. I'm thinking maybe the faster the shutter speed the better for a focused photo. But then again, I know nothing about photography.
By the way, someone once told me that the Nikon digital cameras have the better lenses on the market (for the money.) Is this true?
Jon ­ Foster
is it safe?
Nov 08, 2009 11:16 |  #5
Try the ideas already suggested in the replies above. Good lighting and mounting the camera on a tripod and using the timer to take the shots will improve your pictures considerably. If nothing else, it will tell you if your current camera is up to the job or not.
Jon.
I shoot with a Little Canon
Check out my photos @ PBase.com (external link) & ModelMayhem.com (external link)
golfecho
(I will regret that)
Gallery: 62 photos
Nov 08, 2009 11:48 |  #6
alessandro2009 wrote in post #8976541 (external link)
I don't see a need to be right on top of the product to get the shot. The advice above is good. I would use the tripod to get a larger f-stop (F11 or F16??). Then do the crop in PP.
Facebook (external link) or Website (external link)
Roy ­ G. ­ Biv
Nov 08, 2009 12:58 |  #7
Ta-daaa!!!
https://photography-on-the.net …0&highlight=diy​+light+box
René ­ Damkot
Nov 09, 2009 05:41 |  #8
Focus is not the problem. Depth of field is...
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
Nareg
Nov 09, 2009 08:14 |  #9
So, I'm thinking about getting a Canon SX20. Primarily for these business shots.
Does it matter, or do you guys think a new camera would really not do very much for me, considering how low-res the photos I'm currently taking are.
What kind of difference can i expect for my applications?
Like I said, my current camera is a 6 megapixel Dimage G600 (minolta.)
Appreciate all of your wise advice.
RPCrowe
Joined Nov 2005
Nov 09, 2009 12:06 as a reply to  @ Nareg's post |  #10
I would use a tripod and a light tent.
A light tent and a pair of inexpensive strobes would work just fine. Continuous lights would also be O.K. but the heat they generate might be problematic.
You can fabricate a light tent fairly easily but, I use a folding nylon tent which came with four backgrounds (black, white, gray and red) and cost about $20. It folds away easily and for that price I wouldn't mess with fabrication:
http://cgi.ebay.com …ain_0?hash=item​2c519b15a8 (external link)
A pair of cheap strobes like this will work fine and have the advantage of modeling lights over using hotshoe flashes.
http://cgi.ebay.com …ain_0?hash=item​53ddddaacb (external link)
You will be shooting in manual but, that is not a problem. Just get your exposure down by trial and error and it should not change much from shot to shot.
A pair of short stands like this would work if you want to place your lights on the shooting table next to the tent If not, just get a pair of taller stands. One light on each side of the tent pointing into it will provide even overall lighting with few shadows.
http://cgi.ebay.com …ain_0?hash=item​2ea8e78d63 (external link)
If your part is made of a shiny reflecting material, most light tents have a front panel through which you can shoot without having your reflected image showing in the part.
EOS_JD
Nov 09, 2009 12:45 |  #11
I've not read everything here so apologies if I'm repeating. Looks like Depth of Field is the problem. tamke a couple of steps back from the object and take the shot and then crop to the size you want. This will increase the depth of field and you should see more of the subject in focus.
All My Gear
5D MkIII & 5D MKII + Grips | 24-70 f2.8L IS | 24-105 f4L IS | 70-200 f2.8L IS MkII | 50 f/1.4 | 85 f1.8 | 100 f2.8 | 1.4x MkII | Tamron 17-35 f2.8-4
stsva
Gallery: 45 photos
Nov 10, 2009 10:02 |  #12
Nareg wrote in post #8982242 (external link)
For these kind of shots the Dimage is probably fine. Any of these small digicams should have plenty of depth of field for these kinds of shots.
Some Canon stuff and a little bit of Yongnuo.
Member of the GIYF
Club and
HAMSTTR
٩ Breeders Club https://photography-on-the.net …=744235&highlig​ht=hamsttr Join today!
Image Editing OK
mike_d
Nov 10, 2009 12:41 |  #13
You say these are for low resolution web use, but don't throw out your full resolution originals. You never know when someone down the road might want to re-crop them, print a color catalog, or do something else that will have you wishing you had more than a 350x230 image.
EOS_JD
Nov 11, 2009 18:50 |  #14
No matter the resolution, you still need a capable camera and a correct light setup to get a good image. The camera actually doesn't matter very much in that respect. Your camera should be able to shoot in manual and be able to be used with strobes I'd say for product shots.
All My Gear
974 views & 0 likes for this thread, 11 members have posted to it.
2812 guests, 132 members online
