Help me understand something. I want to try to over power the sun. Let's say by 1 full stop. If I take a ambient reading of f2.8 ISO 100 Shutter 100. Would setting my power on my strobe to f4, but leaving my camera at f2.8 etc be the right way?
extrememc Senior Member 597 posts Joined Oct 2005 More info | Nov 08, 2009 12:40 | #1 Help me understand something. I want to try to over power the sun. Let's say by 1 full stop. If I take a ambient reading of f2.8 ISO 100 Shutter 100. Would setting my power on my strobe to f4, but leaving my camera at f2.8 etc be the right way? Photography is an expression of the mind!!!!!!!!!!!!!
Hermes Goldmember 2,375 posts Joined Mar 2006 Location: London, UK More info | Nov 08, 2009 12:43 | #2 Depends what aperture you want to use.
Nov 08, 2009 13:02 | #3 Hermes wrote in post #8977665 Depends what aperture you want to use. That would all depend on what the meter is reading for ambient light right? Photography is an expression of the mind!!!!!!!!!!!!!
Hermes Goldmember 2,375 posts Joined Mar 2006 Location: London, UK More info | Nov 08, 2009 13:55 | #4 extrememc wrote in post #8977750 That would all depend on what the meter is reading for ambient light right? Not really. Whatever the ambient light reading is, you just make sure your strobe is 1EV more.
Shamir Senior Member 508 posts Likes: 1 Joined Oct 2008 Location: Santo Domingo More info | Nov 08, 2009 15:02 | #5 Underexpose the sun for -1 stop with your camera.. and use the strobe as needed.. Shamir
HastyPhoto Senior Member 953 posts Joined Oct 2009 Location: Philly Burbs More info | Nov 08, 2009 15:43 | #6 Shamir wrote in post #8978203 Underexpose the sun for -1 stop with your camera.. and use the strobe as needed.. if you meter someones face from the strobe then go -1 for the ambient in camera wont that also darken the face of the subject as well as the ambient? 60D | EFS 17-55 2.8 IS | Rode VideoMic Pro | Manfrotto 190XPROB
BrianAZ Goldmember 1,550 posts Joined May 2007 More info | Nov 08, 2009 15:56 | #7 extrememc wrote in post #8977649 Help me understand something. I want to try to over power the sun. Let's say by 1 full stop. If I take a ambient reading of f2.8 ISO 100 Shutter 100. Would setting my power on my strobe to f4, but leaving my camera at f2.8 etc be the right way? Here is the easy way to think about it. First, remove the strobe from the equation. Website
jdhart73 Senior Member 476 posts Joined Mar 2009 Location: Wichita, Kansas More info | Nov 08, 2009 17:20 | #8 The easiest way I have seen to look at it was from Phamster. BLOG
gonzogolf dumb remark memorialized More info | Nov 08, 2009 17:45 | #9 jdhart73 wrote in post #8978790 The easiest way I have seen to look at it was from Phamster. He is not classicly trained nor am I so it was easy to understand. 1. Shutter speed controls Ambient 2. Aperature controls flash on subjects 3. ISO controls both Jake This works for most applications, but to overpower the sun it may not work as on a sunny day if you really want to darken a sky even ISO 100 will not allow you to lower your shutter speed to within max sync speeds so you have to rely on both shuttter speed and aperture to control the ambient. Of course it can still apply using high speed sync, but your flash power is so diminished that you may still have difficulty overpowering the sun.
Nov 08, 2009 17:45 | #10 BrianAZ wrote in post #8978402 Here is the easy way to think about it. First, remove the strobe from the equation. If you want the ambient to underexpose by 1 stop, and the ambient reads f/2.8, and I set my camera to f/4, then the ambient would be underexposed. Without any additional lighting, your subject would be underexposed by 1 stop as well. So, if you now add in a strobe, and get it to meter at f/4, and your camera is set at f/4, then that would mean your subject would be properly lit, but still the areas lit by ambient would be 1 stop underexposed. The main thing is you want to meter using a single ISO and the fastest shutter synch speed of your camera. The shutter speed and ISO should not change. Thanks for the explanation. Photography is an expression of the mind!!!!!!!!!!!!!
Nov 08, 2009 17:47 | #11 In the same manner dealing with lighting ratios. I can set a rim light +1=f4 over beauty dish f2.8 and get a proper exposed face with alittle rim light. Correct? Photography is an expression of the mind!!!!!!!!!!!!!
TMRDesign Cream of the Crop 23,883 posts Likes: 12 Joined Feb 2006 Location: Huntington Station, NY More info | Just to add to and clarify what some others are saying. Robert
Nov 08, 2009 19:17 | #13 Would the easiest way be my controlling the light? Photography is an expression of the mind!!!!!!!!!!!!!
TMRDesign Cream of the Crop 23,883 posts Likes: 12 Joined Feb 2006 Location: Huntington Station, NY More info | Nov 08, 2009 19:41 | #14 extrememc wrote in post #8979381 Would the easiest way be my controlling the light? You can't control the Sun. Robert
Shamir Senior Member 508 posts Likes: 1 Joined Oct 2008 Location: Santo Domingo More info | Nov 09, 2009 04:21 | #15 Bob Hasty wrote in post #8978335 if you meter someones face from the strobe then go -1 for the ambient in camera wont that also darken the face of the subject as well as the ambient?
Shamir
| Latest registered member is Frankie Frankenberry 1834 guests, 137 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
