Thread started 09 Nov 2009 (Monday) 18:01
Badminton anyone?
joonrhee
Nov 09, 2009 18:01 |  #1
First time shooting badminton. It was inside a gymnasium and lighting wasn't too great (but still good)... I shot mainly at 1/30 f2.8. The ones I'm posting here are quite bearable since there weren't too much movements, but the ones with lots of action came out quite blurry (soft).
It was stupid of me not to try, but do you think I would've gotten decent moving pictures by using 1/200 or something faster with higher focus (like f22)?
a7RII • a7C • V12 • L21 • S24GM • S85
Full Gear List & Feedback
SmugMug (external link)
joonrhee
Nov 09, 2009 18:09 |  #2
Here is another one...
mgardner
Nov 09, 2009 18:15 as a reply to  @ joonrhee's post |  #3
Faster shutter and smaller aperture would both serve to let in even less light than what you shot at. My guess is 1/200 and f22 would give you a black picture.
joonrhee
Nov 09, 2009 18:18 as a reply to  @ mgardner's post |  #4
Here are two of faster moving pictures... As you can see, they are quite blurry... Any advice or suggestions would be greatly appreciated.
Thanks.
joonrhee
Nov 09, 2009 18:22 |  #5
mgardner wrote in post #8985948 (external link)
You're right. I think I remember trying that setup and was getting black picture...
I think I was getting the best quality with 1/30 and f2.8 (manual mode and even program mode).
How do you guys take such great, crisp, and fast paced action pictures?
mgardner
Nov 09, 2009 18:26 as a reply to  @ joonrhee's post |  #6
Increase your ISO if you can. Have you tried shooting with your 580?
joonrhee
Nov 09, 2009 18:32 |  #7
mgardner wrote in post #8986009 (external link)
I think it was already at 1600.. or you mean go higher?
and I was not shooting with any flash... I didn't think I needed to...
mgardner
Nov 09, 2009 18:39 as a reply to  @ joonrhee's post |  #8
The shutter speed being too slow is what's causing the motion blur, so to get rid of the motion blur you will need to increase shutter speed. This will let in less light which will underexpose the shot unless you compensate for that by increasing the sensor's sensitivity to light (increasing ISO), use a wider aperture(only possible with your 50 1.4), or add light (flash).
mgardner
Nov 09, 2009 18:48 as a reply to  @ mgardner's post |  #9
With your 50 1.4 @1.4 and ISO set to 3200 you should be able to get 1/250" shutter speed. This will improve your motion blur considerably but you will find you are now battling noise due to high ISO and narrow depth of field due to the wide aperture.
rideuntildeath
Joined Sep 2009
Nov 09, 2009 18:48 |  #10
yes go higher than 1600
remove the noise in post processing the best you can
using your 580 would definatly help as long as its aloud and the players dont mind it going off
keep trying
7D | Canon 70-200 2.8 IS I | Canon 24-70 2.8 L | Canon 10-22 | 50mm 1.8 | 430 EX II | 1 Vivitar 285 HV | Elinchrom Skyports
joonrhee
Nov 09, 2009 21:51 |  #11
mgardner wrote in post #8986086 (external link)
mgardner wrote in post #8986141 (external link)
Thank you very much for kind explanation. I get the idea now, and will try it in the future. :)
DHMN
Nov 10, 2009 00:07 |  #12
Change the focus point to the center spot too.. the drinking fountain and wall and the floor all around the player are focused, though that's a very minor until you increase ISO to get the shutter speed up. You'll need noise reduction eventually also.
EOS 7D Sigma 70-200 F2.8 (1.4 extender outdoors) are the workhorses. 50D for backup, EF 70-300MM USM f/4-5.6 IS, Freelance photographer for local newspapers and my website viewthroughmylens.net (external link)
Zivnuska
Gallery: 72 photos
Nov 10, 2009 05:38 as a reply to  @ DHMN's post |  #13
joonrhee,
Welcome. I enjoy seeing your pictures. It will help everyone to know the shutter speed, aperture and ISO of each picture taken. You will need to post those or leave them attached to your pictures (EXIF data).
Sports action shots will need to have a shutter speed of at least 1/400 second and preferable even faster in order to stop fast action. 1/640 sec is better! That usually means an aperture of 2.8 or larger (note: f/22 is a smaller aperture even though 22 is a larger number than 2.8 It also means high ISO like 3200. These numbers will vary depending on the gymnasium lighting.
You have some very nice equipment that is well suited for sports. When you shoot at that facility at f/2.8 (Av aperture preferred) and ISO 3200, what shutter speed do you get?
Once we get those numbers, we can advise you on how to proceed from there.
Phil
Here are some pro sports photography tips:
http://web.mac.com …Site/Podcast/Po​dcast.html (external link)
www.zivnuska.zenfolio.​com/blog (external link) = My Blog
www.zivnuska.zenfolio.​com (external link)
"It's not tight until you see the color of the irides."
joonrhee
Nov 10, 2009 13:44 |  #14
DHMN wrote in post #8987918 (external link)
Thank you. I'll keep that in mind. :)
Zivnuska wrote in post #8988656 (external link)
joonrhee,
Phil
I'm afraid I will not be shooting anytime soon. Probably towards end of this year or early next year... But, thank you so much for your tip about shutter speed needing to be at least 1/400sec to shoot sports shots. Next time, I'll try at 2.8 with ISO 3200 in Av, and find out what shutter speed I get. Thanks again!! :D
mgardner
Nov 10, 2009 14:18 as a reply to  @ joonrhee's post |  #15
If your staying with an aperture of 2.8, you will only gain one stop. In other words you will go from 1/30" to 1/60". You need about three more stops than that.
3,704 views & 0 likes for this thread, 8 members have posted to it.
Badminton anyone?
2773 guests, 166 members online
