Thread started 24 Aug 2001 (Friday) 18:45
G1 and studio flashes
killroy
Joined Aug 2001
Aug 24, 2001 18:45 |  #1
I've almost every post and can't seem to find this answered...
Can the G1 or the upsoming G2 be used with studio lighting (flashes). I would like to use the G1 (or G2) as a preview camera for my studio set ups and I want to see if the cameras can use these lights in the manual or auto modes.
sjguenard
Joined Aug 2001
Aug 25, 2001 02:36 |  #2
User claims flashes (on hotshoe) with more than 6V trigger voltage is harmful to Canon cameras.
See http://www.botzilla.co​m/photo/G1strobe.html (external link)
I personally could never get a (non-Canon) flash to fire. Maybe I've already fried my G1 external flash circuit with injudicioius attempts with my Quantaray QA 25.
killroy
Joined Aug 2001
Aug 25, 2001 19:41 |  #3
I understand about putting a non-Canon flash on the hot shoe can be bad....I want to know if I can trigger studio lights with the G1 or G2 and will it synch? I was planning on using a Quantum Radio Slave 4 to trigger my three studio lights but I want to make sure that the synch will come out when I push the shutter.
rkurtycz
1 post
Joined Aug 2001
Aug 29, 2001 13:23 |  #4
I hook up to a Calument (Bowens) Travelight kit using a Wein Safe-Sync HS volage regulator. It plugs mounts on the hotshoe and has a single synch cable port on the front. Seems to work fine.
Exposure settings are much different for the G1 than what is metered or actually used with a Nikon F5 in the studio.
jmphotos
Joined Jun 2001
Aug 30, 2001 13:11 |  #5
The G1 will trigger my White Lightenings. You can use the in camera flash, or one of the Canon EX series; and turn the flash (set on low power) so the White Lightening can 'see' it.
Jim
Mark ­ Bennett
Joined Mar 2002
Mar 14, 2002 05:05 |  #6
Hi
Where can I get one of these: Wein Safe-Sync HS volage regulator
Ideally it should have a hot shoe on it as well so I can use it with flashes as well as studio lights.
M
2,988 views & 0 likes for this thread, 5 members have posted to it.
1463 guests, 148 members online
