Up at the jumps with new flashes, thoughts and crit would be much appreciated!
![]() | HTTP response: NOT FOUND | MIME changed to 'image/gif' | Redirected to error image by FLICKR |
KD80 Member 68 posts Joined May 2009 More info | Nov 11, 2009 06:24 | #1 Up at the jumps with new flashes, thoughts and crit would be much appreciated!
[ Flickr!!
Jagman Member 94 posts Joined Sep 2004 Location: Perth,WA, Australia More info | Nov 11, 2009 08:51 | #2 It looks like you've got the flashes going okay (although the rider has a flash shadow from his arm in the second photo on his face) but in the second photo especially you've got too much going on. It is nice to see the path that the rider will take, but there's so much else to draw the eye that I find myself forgetting that there is a rider there. Personally I prefer to shoot jumps with a wide angle right up close, with the rider near the top of the frame and as much clear air beneath as you can get, to make the jump look as big as possible. Crouching down as low as you can get just to the side of the lander usually works well, but it will all depend on the situation and the tricks the rider is doing.
texaskev Goldmember More info | Nov 12, 2009 23:55 | #3 Good shots, did you use off camera lighting? If so where were they set up at? Canon 1DX II, 1DX, 11-24 F4 L, 100 F2.8 L, 16-35 F2.8 L II, 17-40 F4 L, 24-70 F2.8 L II, 24-105 F4 L II, 70-200 F2.8 L II
| Latest registered member is josetide 1056 guests, 167 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
