Thread started 11 Nov 2009 (Wednesday) 13:28
70-200mm 2.8 IS - needs different MA for different distances
psxindo
Nov 11, 2009 13:28 |  #1
I'm not sure if this is the camera or the lens.
I'm using 7D
@ 200mm f2.8 on both
when I shoot something at around 10 ft, I would need +5 MA
but when I shoot something at around 40 ft, I would need +15 MA
Would this be a lens issue, and I need to send it in... since it's still under warranty?
5D mkIII | 5D mkII | 6D | EOS M | 16-35L | 24-70L | 70-200L 2.8 IS mkII | EF-M 22 | 50 1.4 | 85L | 100 2.8 macro | Tamron 17-50 2.8 | 2x 580 ex II | 580 ex | 2x sunpak 383 | 134GB CF |
Wishlist | 14L | 24L | 35L | 50L | 100L macro | 135L | 15 2.8 FE | 17L 4 TS | 45 2.8 TS | 90 2.8 TS |
gasrocks
Nov 11, 2009 13:35 |  #2
Have you ruled out all other variables besides the lens?
Todd ­ Lambert
I don't like titles
Nov 11, 2009 13:41 |  #3
This is the major problem with MA. I wish Canon would add at least one more preset to it. So, then you can MA for short and for long.
Or of course, you can just gets primes instead. ;-)a
psxindo
Nov 11, 2009 13:48 |  #4
The problem is not with the focal length, but the distance of the subject.
Todd Lambert wrote in post #8997276 (external link)
Todd ­ Lambert
I don't like titles
Nov 11, 2009 13:54 |  #5
If you have someone 10ft away and you are at 70mm. Then the person is 40ft and you're still at 70mm? That type of thing?
psxindo
Nov 11, 2009 14:05 |  #6
yes, but both at 200mm.
Todd ­ Lambert
I don't like titles
Nov 11, 2009 14:20 |  #7
Hmm, not sure, but object distance shouldn't matter. It either front focuses or it back focuses which you can correct with MA. If it's doing something other than those, then yes, probably need to send it in.
Canon ­ Bob
Nov 11, 2009 14:25 as a reply to  @ Todd Lambert's post |  #8
At 10 feet then there's a chance that aberrations may be influencing the AF performance a little. Logically, most of us would use the centre AF point for a test like this but it would be interesting to see if the results differed using one of the outer points (appreciating that overall AF accurracy might be degraded)
Bob
1Dx2 (2), 5DSR, 1Ds3, 1D4, 5D2(590nm), 5D2(720nm) EF600 EF400 EF300-II EF300 EF200 EF200-II EF180L EF135L EF100 EF85-II EF50L TS-E17/4 TS-E24L-II TS-E45 TS-E90 MP-E65 EF70-200-II EF24-70/2.8-II EF16-35/4 EF8-15/4 EF11-24/4 Zeiss 15/2.8 21/2.8 25/2 28/2 35/1.4 35/2 50/2 85/1.4 100/2 135/2 T/C's L-SC & a WIFE!
psxindo
Nov 11, 2009 14:54 |  #9
yes, when testing I used center focus point only.
Basically, when shooting something around 10 ft away, I would need +5 MA, but when farther away at around 30-40 ft with the same +5 MA, it would be front focusing. Which need a +15 MA to get a sharp picture.
Mr. ­ Clean
Nov 11, 2009 15:25 |  #10
What does +15 look like at 10ft? 10ft I think is too close to MA that lens at 200mm though in my opinion.
Mike
some shots @ Zenfolio (external link)
garycoleman
Nov 11, 2009 15:46 |  #11
get it calibrated. I got my 70-200 2.8 IS repaired and it's the sharpest at 0 MA with my 7D
Canon 5D MKIII | Canon 60D | 24-70mm f/2.8L II | 17-55mm f/2.8 IS | 70-200mm f/2.8L IS | 580EX II
Chez ­ Wimpy
Nov 11, 2009 17:52 |  #12
Yes, I certainly have this problem as well. With the 70-200/2.8IS I haven't much bothered switching up the MA (not so critical to my work, I got it set at about 25 meters and let it be), but with my 85L, it is mandatory if I want to get acceptable results at f1.2. Head-shoulders portraits is +0 but for full-body distances, +5. I learned this the hard way after my first time going outside with the lens and losing about 1/2 the shots to FF.
-CW
生きのいい魂が手に余る
5D2 - 20D - 550D
Canon 24LII - 35
- 50II - 85 - 85L - 135L - 300/4 - 70-200/2.8IS - TSE 24L2 - 90
Sigma 15 - 30 - 50 - 12-24
gte357s
Nov 11, 2009 19:34 |  #13
Todd Lambert wrote in post #8997476 (external link)
No .. from my observation and testing of my 70-200 F4 and Tamron 60mm F2 macro. The distance to object (focus distance) do matters in some of the lens. For example, it is well know that the 70-200 image is soft (or actually cannot focus) at the minimum focus distance (MFD) of 1.2m at focal length of 200mm.
When I test the Tamron 60mm F2 macro, it is even worse. It focus ok at macro distance (0.3m-1m), then it becomes front focus as I step back (~1.5m), then it becomes back focus if I am very far away (>4m) from the object.
Now, I can understand why prime is preferred by some people. I think it is just technically a lot easier to make a prime that will focus properly, there is one less variable to play with. There are now 3 variables in zoom lens that can impact the image - the aperture, the focus distance, and the focal length.
Canon 5D MK I | Canon 24-70 F2.8 L | Canon 70-200 F2.8 L IS I | Sigma 85 F1.4 | Tamron 1.4x TC | Canon 430 EXII
psxindo
Nov 13, 2009 02:21 |  #14
Would sending it in fix the problem?
2,179 views & 0 likes for this thread
Latest registered member is McCartyM
918 guests, 189 members online
