i need to get a set of external HDs soon. i know the 1 tb drives by seagate and western digital are fairly reliable and i know there are problems with 2 tb drives.
so i'm trying to decide beteen 1tb and 1.5 tb drives.
thanx,
ed rader
edrader "I am not the final word" More info | Nov 13, 2009 16:16 | #1 i need to get a set of external HDs soon. i know the 1 tb drives by seagate and western digital are fairly reliable and i know there are problems with 2 tb drives. http://instagram.com/edraderphotography/
powaysteve Senior Member 518 posts Likes: 9 Joined Jun 2008 Location: Poway, California More info | Nov 13, 2009 16:44 | #2 I've had a La Cie D2Quadra Big Disk (1.5Tb) for about 6 months now and it has worked flawlessly. I use the eSata connection but it also comes with USB and Firewire.
tgara Goldmember 2,336 posts Likes: 8 Joined Sep 2007 Location: Connecticut, USA More info | Ed, are you set on Western Digital and Seagate, or are you open to considering other brands? If so, the G Technology products may be worth a look. EOS 5D Mark III
iceman1 Senior Member 467 posts Joined Aug 2008 Location: IN, USA More info | Nov 13, 2009 20:19 | #4 Between WD and Seagate, I would go with WD because of failure/firmware issues some Seagate drives have had this past year. Gear & Feedback
Nov 13, 2009 20:28 | #5 tgara wrote in post #9011186 Ed, are you set on Western Digital and Seagate, or are you open to considering other brands? If so, the G Technology products may be worth a look. http://www.g-technology.com/products/g-drive.cfm They use high quality components that have proven very reliable. I have a 500 GB G-Drive, and it has operated flawlessly for two years. They have fancier products too if those suit you. Good luck! i'll have to ask around and see if some of the more eclectic brands spec higher grade components ... like say LG and samsung do for their flat panels. http://instagram.com/edraderphotography/
bohdank Cream of the Crop 14,060 posts Likes: 6 Joined Jan 2008 Location: Montreal, Canada More info | Nov 13, 2009 20:29 | #6 Avoid the .11 Seagate models and you'll be OK. Bohdan - I may be, and probably am, completely wrong.
Nov 13, 2009 20:29 | #7 iceman1 wrote in post #9011214 Between WD and Seagate, I would go with WD because of failure/firmware issues some Seagate drives have had this past year. normally i would just buy seagate and be done with it but i heard the seagate 1.5s had problems. i wonder if the newer units are any better? http://instagram.com/edraderphotography/
Nov 13, 2009 20:36 | #8 I have an external 1TB Cavalry drive I got on NewEgg for $89(although I don't know the actual HD make.) No problems so far. *fingers crossed* Web: Erotiklab
Nov 13, 2009 20:42 | #9 bohdank wrote in post #9011257 Avoid the .11 Seagate models and you'll be OK. I've been using Seagate drives for years and haven't had 1 problem. The WD drives don't work well in RAID setups because they have a tendancy to constantly go to sleep. is the freeagent 1.5 TB one to avoid? http://instagram.com/edraderphotography/
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Nov 13, 2009 21:12 | #10 ed rader wrote in post #9011254 i'll have to ask around and see if some of the more eclectic brands spec higher grade components ... like say LG and samsung do for their flat panels. i've never had a seagate or WD fail so i'm inclined to go with one of those as long as they make a dependable product. like i said in the OP i know the 1 tb HDs are safe but i'm not sure about the 1.5s. ed rader In the past two years I have had one Seagate fail (my daughter's laptop) and one WD fail (an occasionally powered WD MyBook). My money is on something using a Samsung or Hitachi or Toshiba (before being sold to one of the big name harddrive makers) You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
Sean Goldmember 1,714 posts Joined Apr 2008 Location: Ottawa, Ontario More info | Nov 13, 2009 21:32 | #11 I had my 640 external MyBook by WD fail out of box (less than 2 hours). Hard drives die infantile or with in approx 18 months. If they don't they will last a very long time. I have a very old 8GB drive that is IDE and it still works to this day. Canon 50D - 17-55mm F2.8 IS - 300mm F4L IS - 70-200mm F4L IS - 50mm F1.8 - 580EX II & 430EX - Full Gear Listing
thumper8 Senior Member 610 posts Joined Apr 2008 Location: Vancouver, BC More info | I have a LaCie 1TB hard drive and it works flawlessly through USB - the 'Design by Neil Poulton' black block model was not my first choice but it was on sale, and it has started to grow on me - http://www.lacie.com …cts/product.htm?pid=11062 aka Tony
iceman1 Senior Member 467 posts Joined Aug 2008 Location: IN, USA More info | Nov 13, 2009 21:58 | #13 I'm not sure how widespread the Seagate issues still are, but any hard drive can fail, regardless of brand. Sometimes you just get a dud or one that took some hard hits during shipping that won't last for a week while others will claim to have had the same model going strong for years. I have had 10+, mainly Seagate, Samsung, and Western Digital drives over the years and only 1 has died. Gear & Feedback
rklepper Dignity-Esteem-Compassion 9,019 posts Gallery: 2 photos Likes: 14 Joined Dec 2003 Location: No longer living at the center of the known universe, moved just slightly to the right. Iowa, USA. More info | Nov 13, 2009 23:07 | #14 Personally I would avoid externals that come prepackaged. i would buy an external box and put an enterprise level drive in it, for example the Seagate ES.2. They just do not put their best drives into the prepackaged drives. Doc Klepper in the USA
Lisa "At least once a day" 2,325 posts Joined Feb 2009 More info | Nov 13, 2009 23:26 | #15 I have a 8 year old 80gb WD that is still working, Came from my HP (still kicking) I am currently using it in our HDD media player. I am using 250 & 500gb WD in my HP at the moment. Gear (full list)
| Latest registered member is semonsters 1523 guests, 132 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
