Thread started 13 Nov 2009 (Friday) 16:42
conecting 2 computers
rayman ­ 64
Nov 13, 2009 16:42 |  #1
hi i've got a couple of tower desktops is there any way of conecting them and running them as one system via some form of cable just a thought thanks ray
My website http://www.ortonphotog​raphy.co.uk (external link)
basroil
Nov 13, 2009 17:14 |  #2
Two towers can be run as two towers. You can remote desktop from one to the other, but they will always be two. Simply use an Ethernet cable and you can remote desktop (or if both are on your home network, then they already can do this, given that the computer you are connecting to has windows pro (xp, vista, or 7 all have a professional/business version, 2000 is always professional)
Now, if you want to run a distributed computing app, you'll need a few things:
1) a better forum, this is for PHOTOGRAPHY, not computer system building. People here can be knowledgeable, but you are asking for the stuff that specialized companies sell for millions.
2) fast interconnects, fibre or other, most setups probably cost more than your computers and camera equipment combined
3) High performance computing OS. Windows HPC and several types of linux/unix work, but they can't run photoshop correctly.
4) Time, because these things aren't the type of builds you can do overnight.
tim
Light Bringer
Nov 13, 2009 20:00 |  #3
Depends what you're trying to do. A crossover network cable will let them communicate cheaply, but they'll always look and work like two computers.
BeritOlam
Nov 14, 2009 02:29 |  #4
basroil wrote in post #9010355 (external link)
Two towers can be run as two towers....
Really? I've been wondering about that..... ;)
Tim, as Basroil points out, it would be quite easy to set up *one network* with 2 towers....but combining 2 towers to work as *one system* is a very different animal altogether.
You'll have to expand a bit on your initial question if you want more feedback.
Blessed are the young, for they shall inherit the national debt. – Herbert Hoover
rayman ­ 64
Nov 14, 2009 07:43 as a reply to  @ BeritOlam's post |  #5
thanks for all your suggestions all im trying to do if possible is to have say a tower as a main computer and the other one as some sort of slave allowing me to move data/files from one to another using one screen,mouse,keyboard etc again thanks
NinetyEight
"Banned for life"
Nov 14, 2009 08:19 |  #6
If it's just storage you are after, just move the hard drive(s) into the main machine or fit them in external enclosures for portability/backup.
Bat as Tim said, to connect them up via the NIC cards just plug a cross-over cat-5 cable between them, You may have to make sure they are both in the same workgroup and in the same IP subnet and enable file sharing on the drive(s)
Kev
highbarger
Nov 14, 2009 08:40 |  #7
rayman 64 wrote in post #9013022 (external link)
If you want to run two machines from one keyboard/monitor and mouse combination, you might be looking for a KVM switch. Here is a link (external link) to one example of a KVM switch. I don't have any experience with this product so this is NOT an endorsement, for educational purposes only:p
JohnnyEgo
Nov 14, 2009 08:58 |  #8
Between work, personal, and family computers, I have five computers on a wired network and three more on wireless. I have an off-the-shelf router and a bunch of CAT5 cable. It cost about $50 all told to link them all together. Didn't even have to mess with any protocols, because XP did all the configurating for me many years ago. The knowledge burden for setting up a small home network these days is lower then what it took to remove your computer from the box and hook up all the peripherals.
At the computer I am on right now, I have a tower and a laptop hooked into an old TrendNet 2 port KVM switch. I can press a hot key on the keyboard, and instantly switch monitor, mouse, and keyboard from laptop to tower and vice-versa. In either one, I can transfer data back and forth with ease over the network. In fact, some of my program defaults on my laptop save and retrieve files to a folder on my tower automatically. What's more, I can access my DVD and CD drives and printers from my tower by any other computer in my house, as long as both are on.
Many of the newer KVM switches incorporate USB ports, so you could presumably plug a powered or unpowered hub and share all your USB peripherals simultaneously. You can get a good KVM switch in the $30-50 range as well.
New guy with a camera.
JohnnyEgo.com (external link)
nwa2
Nov 14, 2009 09:18 |  #9
Why do you want to do this? Is it to multi task?
Canon 6D; 7D; 40D:
There are many tomorrows', but only one today!!
[SIZE=1][COLOR=Black]http://www.Abercrombie​.me.Uk (external link)
http://imagesix.wordpr​ess.com/ (external link)
basroil
Nov 14, 2009 12:00 |  #10
http://www.howtogeek.c​om …between-windows-7-and-xp/ (external link)
http://support.microso​ft.com/kb/304040 (external link)
http://technet.microso​ft.com/en-us/library/bb727037.as​px (external link)
Happy reading
rayman ­ 64
Nov 14, 2009 12:31 |  #11
JohnnyEgo wrote in post #9013243 (external link)
thats exactly what i was thinking of a kvm switch i,ll look into that and again many thanks for the links and advice:lol:
rayman ­ 64
Nov 14, 2009 12:42 as a reply to  @ rayman 64's post |  #12
basroil thanks for the help and the links very appreciated:)
Bobster
Nov 16, 2009 07:58 |  #13
i control my Laptop over my network with my workstation mouse and keyboard using a free utility called Synergy (external link)
it allows me to copy and paste text as well, which is useful when im chatting over IM and someone sends me a link etc..
but if you only have 1 monitor a KVM Switch is your easy answer
Robert Whetton (external link) Dorset Portrait & Events Photographer | Photoshop Guru
DIY Monitor Hood (external link) | Gear | Tweet (external link) | Insta (external link) | FoCal 2 (external link)| Ultimate RAW Editor (external link)
egordon99
Nov 16, 2009 10:47 as a reply to  @ Bobster's post |  #14
I'm getting a new "Photoshop" dedicated PC, and rather than trying to migrate all my iTunes/Office/Outlook/​misc. stuff from my old PC (which works fine for lightweight computing), I'm going to use a RemoteDesktop app to access the old PC (which runs the RD server) from my new PC (runs the RD client)...
I forgot which one I've used in the past, but here's a good article on some options -
http://www.online-tech-tips.com …screen-sharing-solutions/ (external link)
If both PCs are running XP/Vista/whatever Professional, you can use Window's RemoteDesktop.
basroil
Nov 16, 2009 10:58 |  #15
egordon99 wrote in post #9024345 (external link)
False: You only need pro version on the one you are remote desktop'ing to, all versions have a remote desktop connection client, only pro has the server.
1,708 views & 0 likes for this thread
Latest registered member is idauria
1109 guests, 255 members online
