Should I use the technique of expose to the right even if I'm shooting JPEG?
FellipedePaula Senior Member 438 posts Joined Jan 2008 Location: Brazil More info | Nov 14, 2009 07:56 | #1 Should I use the technique of expose to the right even if I'm shooting JPEG?
PhotosGuy Cream of the Crop, R.I.P. More info | Nov 14, 2009 08:15 | #2 Expose to the right is really designed for RAW where you "overexpose" & can correct the exposure before conversion. FrankC - 20D, RAW, Manual everything...
JeffreyG "my bits and pieces are all hard" More info | Nov 14, 2009 08:22 | #3 Fellipe de Paula wrote in post #9013063 Should I use the technique of expose to the right even if I'm shooting JPEG? Expose to the right implies pulling back the exposure in post processing to reduce noise and maximize dynamic range. My personal stuff:http://www.flickr.com/photos/jngirbach/sets/
rral22 Senior Member 885 posts Likes: 1 Joined Jul 2008 Location: Saskatchewan, Canada More info | Nov 14, 2009 09:01 | #4 My thinking is that, if I am shooting Jpeg, I want the exposure exactly where it needs to be. If I am shooting Raw, I want the exposure to produce the best file I can get for the post processing I will do to it. To me, ETTR is for Raw shooting only.
nwa2 Goldmember 1,131 posts Joined Oct 2006 Location: Manitoba More info | Nov 14, 2009 09:14 | #5 Fellipe de Paula wrote in post #9013063 Should I use the technique of expose to the right even if I'm shooting JPEG? No, get it right first time with JPEG. Expose to the right with RAW. Canon 6D; 7D; 40D:
tzalman Fatal attraction. 13,497 posts Likes: 213 Joined Apr 2005 Location: Gesher Haziv, Israel More info | Nov 14, 2009 10:28 | #6 You need to understand a basic difference between RAW and jpg (or any other RGB format). RAW data from the sensor is in linear space. Because human perception is not linear, part of the conversion to an RGB color image involves the application of a gamma curve (usually gamma 2.2). Moreover, RAW is 12/14 bit and jpg is 8 bit. Pulling the exposure of linear RAW data is a relatively simple process of division, but doing it after gamma correction and in lower bit depth limits the amount of tonal adjustment that can be done without loss of quality. Elie / אלי
| Latest registered member was a spammer, and banned as such! 2978 guests, 130 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
