Thread started 14 Nov 2009 (Saturday) 22:44
Win 7 and CS3 Extended Crashes Network Connection WHY?
TheFloridaShooter
Nov 14, 2009 22:44 |  #1
WHy is this happening. Brand new computer and when I loaded CS3 Extended it adds a Network Connection that takes over and won't allow anything to open in Internet Explorer. Sometimes I can do a winsock reset and get things back running.
Whats going on??????
Any ideas?????
1Dx MKII | 1Dx | 5D MKIV | 5D MKIII | 5Ds r | 5Ds | 7D MKII | 7D | G16 | G3x | EOS M & M3 | 800 f5.6 | 600 f4 | 400 f2.8 | 300 f2.8 | 200-400 f4 | 100-400 f4.5 - 5.6 II x 2 | 70-200 f2.8 | 14 f2.8 II | 50 f1.2 | 50 1.4 | 85 f1.2 | 135 f2 | 24-70 f2.8 II | 11-24 f4 | 35 f1.4 II | Pentax 645Z | SMC Pentax-DA 645 25mm F4 AL | SMC Pentax-D FA 645 55mm F2.8 AL | Pentax 90mm f/2.8 D FA 645 Macro ED AW SR | SMC Pentax-D FA 645 200mm f/4 IF | SMC Pentax-D FA 645 300mm f/4 ED IF | SMC FA 645 400mm f/5.6 ED IF Lens
MaxxuM
Nov 15, 2009 00:50 |  #2
You can turn this off if you go to Help > Adobe Update > Automatically check for Adobe updates: and uncheck that option. You can also disallow the updater via your firewall.
I'm running CS3 Master Collection & After Effects with Windows 7 64-bit and don't have any problems. Adobe shouldn't have any effect unless there are other problems with your network connection. Could you describe the problem a little more?
TheFloridaShooter
Nov 15, 2009 01:35 |  #3
It appears after i download CS3 And Bridge I can't access a webpage. The I have to do a winsock reset.
MaxxuM
Nov 15, 2009 01:52 |  #4
And you're doing a "netsh winsock reset" command then restarting Windows?
TheFloridaShooter
Nov 15, 2009 01:55 |  #5
Yes to the reset command But after downloading CS3 Extended I have to reset winsock atleast 4 times per day. Is there a fix fir this? I really need to get CS3 and Bridge loaded in this computer. Lightroom 2.5 is running clean
MaxxuM
Nov 15, 2009 02:01 |  #6
Have you tried: netsh int ip reset c:\resetlog.txt
TheFloridaShooter
Nov 15, 2009 02:04 |  #7
No I haven't tried that. I ended up removing CS3 and it's other files. Then I restored the system. And now the netwrok connection is operating correctly.
MaxxuM
Nov 15, 2009 02:08 |  #8
Sounds like CS3 corrupted your systems network tables. It's pretty rare since they're rebuilt pretty often. Maybe you can try installing with elevated privileges.
TheFloridaShooter
Nov 15, 2009 02:08 |  #9
Man if you know anyone that talk me through this please PM me. I've been working on this for most of the day. I'm heading off to bed now. Thanks
TheFloridaShooter
Nov 15, 2009 02:09 |  #10
hopw would I install with elevated privileges?
basroil
Nov 15, 2009 02:21 |  #11
TheMissouriShooter wrote in post #9017462 (external link)
right click the installer and "run as" should work
MaxxuM
Nov 15, 2009 02:22 |  #12
In Vista and 7 you can run programs as administrator - but in truth, it's still limited. Administrator user is actually a true administrator - so if you shift click the installer you'll see Run as different user and you'll use Administrator. You'll also have to activate the hidden Administrator account (you can google the procedure).
1,334 views & 0 likes for this thread
Latest registered member is KathKirk33
1007 guests, 336 members online
