Thread started 15 Nov 2009 (Sunday) 12:23
Anyone focus EF50 f/1.8 manually?
Vendee
Nov 15, 2009 12:23 |  #1
In a few days time I'm going to be shooting some after dark b&w film shots. I've got a couple of film bodies and my first choice would be my Pentax ME Super with 50mm 1.7 lens. Its a manual focus combination but the split screen focusing makes it straightforward. The problem is that the ME Super will only go up to 1600 iso and I'll be using using 3200 film.
So that means using my EOS 3 but the only fast lens I have is my nifty fifty and as we know, that doesn't really autofocus well in poor light. So I'm looking at using it in manual focus mode.
Has anyone used their nifty fifty in manual mode at night? If so, what were the results like?
| EOS 6D| EOS 3 |EF 24-105mm f/4L|EF 70-200mm f/4L IS |EF 40mm f/2.8 STM | EF 50 f/1.8 II | Sigma 35mm f/1.4 Art | Pentax MX |Pentax ME Super|Pentax K1000|Kiev 4A|Yashica Electra 35 GTN|Yashica 24|Ricoh GR III
My stuff:- www.giverin.co.uk (external link)
wimg
Nov 15, 2009 12:36 |  #2
Vendee wrote in post #9019191 (external link)
Actually, you can underexpose the ME by 1 stop, by switching to manual.
The nifty 50 focuses fine in low light, at least IME, but you need to focus on something with good contrast. Don't focus on a black shirt in the dark, but on the transition from the dark shirt to the face. MF is fine too; but maybe get a focusing screen with split wedge for the EOS 3?
Kind regards, Wim
Vendee
Nov 15, 2009 14:18 |  #3
wimg wrote in post #9019274 (external link)
In what way? The only way you could do that is by doubling the metered shutter speed. I know the ME Super has exposure compensation where you can overexpose or underexpose up to two stops but at 1600 ISO you can only overexpose. It won't let you underexpose at max ISO.
If I use the EOS 3, I've also got the option of pushing to it 6400 if circumstances dictate. Thanks for your advice.
macroimage
Nov 15, 2009 14:44 |  #4
If you want the 50/1.8 to AF well in the dark, put your 430EX II on the camera and use the focus assist light on flash. It will project some red stripes for the camera to focus on. Then turn the flash off before taking the picture. Of course this will only work where your subject is close enough to project the AF light.
You can also pick something the same distance away where the AF will lock on, like a light. Or light the subject with a flashlight to focus.
Focusing manually with the 50 requires being very gentle with the focus ring. The problem is identifying by eye when it is in focus. Using the focus confirmation in the camera will work but has the same limitations as autofocus. Stopping down to f/22 will cover a lot of focus error however if you don't mind lots of depth of field and diffraction spikes around the light sources.
Photo Gear
Vendee
Nov 15, 2009 15:06 |  #5
macroimage wrote in post #9019871 (external link)
f/22 handheld at night isn't really an option.
Yeah, I admit I didn't mention "handheld" in my original post :lol:
wimg
Nov 15, 2009 16:56 |  #6
Vendee wrote in post #9019751 (external link)
I could be wrong, as I sold my ME well over 8 years ago now, but you can switch to manual, i.e. metered or manual mode only. Set to 1600 iso, meter, and up the shutter speed by a stop, or close the aperture by a stop. Or two stops in case of 6400 iso.
Kind regards, Wim
P.S.: I may have a chance at Christmas to see it again, but I guess that may be too late :D.
Vendee
Nov 16, 2009 05:50 as a reply to  @ wimg's post |  #7
I've given it some thought and I reckon that I might have to push the film to 6400 to suit the conditions. That realisticlly means using the EOS 3 rather than the Pentax. As for the lens choice, I'd forgotten that my 24-105L has got 3 stop IS so at its min f/4 aperture, it should be a better choice. It will find focus better in the dark and f/4 will give better dof than the nifty fifty @ f/1.8
1,227 views & 0 likes for this thread, 3 members have posted to it.
1454 guests, 128 members online
