10"x40", composed of 21 images.
![]() | HTTP response: NOT FOUND | MIME changed to 'image/gif' | Redirected to error image by FLICKR |
gregpphoto Goldmember 1,123 posts Likes: 2 Joined Jun 2008 Location: NJ More info | Nov 15, 2009 19:25 | #1 10"x40", composed of 21 images.
Slack3r Junior Member 28 posts Joined Nov 2007 More info | Nov 15, 2009 20:24 | #2 Wow, I really like that a lot, what is it that you used for a subject? Jeff Hardy
Nov 15, 2009 23:07 | #3 Wood glue dripped into an acrylic tank of water. I would only get one or two usable shots per series of drips, so it was a lot of emptying, washing, and refilling. Squeezing hard or soft, holding the bottle close or far from the surface of the water, and things of that nature contribute to how the glue will look. I used two cheap lamps to light either side.
PlayersZ28 Senior Member 550 posts Joined Jan 2008 Location: Caledon,ON More info | Nov 16, 2009 00:46 | #4 Wow! an interesting effect! Thanks for the how-to info as well. Canon -> A1, 1D (gone), G10, XT IR, 7D and some glass of various lengths and colors
FlyingPhotog Cream of the "Prop" 57,560 posts Likes: 178 Joined May 2007 Location: Probably Chasing Aircraft More info | Nov 16, 2009 00:58 | #5 Roger Dean on Line 2... Jay
FelixDeSouze Senior Member 829 posts Joined Nov 2009 Location: Perth, WA More info | Nov 16, 2009 07:49 | #6 I really like it.. I love doing things like this! Canon EOS 6D| Canon 50mm f/1.8 MkII | Canon 70-200mm f/2.8 IS USM II [COLOR="red"]
jgrussell Looking around nervously 18,758 posts Likes: 14 Joined May 2008 Location: NJ USA More info | Nov 16, 2009 10:31 | #7 LOVE it. -- jgr
Olli -Mighty Mod- More info | Nov 16, 2009 14:49 | #9 gregpphoto wrote in post #9022261 Wood glue dripped into an acrylic tank of water. I would only get one or two usable shots per series of drips, so it was a lot of emptying, washing, and refilling. Squeezing hard or soft, holding the bottle close or far from the surface of the water, and things of that nature contribute to how the glue will look. I used two cheap lamps to light either side. Great shot Greg, and I'm glad you shared the set-up as well. (Now to buy some cheap glue ...) My Instagrams
MikeFairbanks Cream of the Crop 6,428 posts Likes: 2 Joined Jun 2009 More info | Nov 16, 2009 20:54 | #10 That is so cool, and some of the sections could be cropped and isolated. Thank you.
FelixDeSouze Senior Member 829 posts Joined Nov 2009 Location: Perth, WA More info | Nov 17, 2009 02:55 | #11 I presume you set the camera to autotake several shots in a row? Canon EOS 6D| Canon 50mm f/1.8 MkII | Canon 70-200mm f/2.8 IS USM II [COLOR="red"]
Nov 17, 2009 07:42 | #12 FelixDeSouze wrote in post #9029104 I presume you set the camera to autotake several shots in a row? Nope. Since I was dripping the glue with one hand, and using a flash light in the other to add some extra light, I wound up using my big toe to press the shutter on the remote I had taped to the ground!
FelixDeSouze Senior Member 829 posts Joined Nov 2009 Location: Perth, WA More info | Nov 17, 2009 08:04 | #13 gregpphoto wrote in post #9029724 Nope. Since I was dripping the glue with one hand, and using a flash light in the other to add some extra light, I wound up using my big toe to press the shutter on the remote I had taped to the ground! haha, I like your style!! Canon EOS 6D| Canon 50mm f/1.8 MkII | Canon 70-200mm f/2.8 IS USM II [COLOR="red"]
Cyclop Cream of the Crop 6,899 posts Joined Jun 2007 More info | Nov 17, 2009 08:27 | #14 Unique concept/image, well done. Canon 50D w/grip, Canon 7D, Mark II w/grip, Tokina UWA 11-16 2.8, Canon 17-55 2.8 IS, Canon 70-200 2.8 L IS, Canon 300 4 L IS, Canon 400 5.6 L, Canon 100 "macro" 2.8, Canon 60 "macro" 2.8, Canon Extender 1.4xII, Gitzo 3531S tripod w/Markins M20 ballhead, Gitzo GT2531EX tripod, Bogen-Manfrotto 681B monopod w/3232 head.
Nov 19, 2009 10:23 | #15 Glad to see everyone is diggin it!
| Latest registered member is semonsters 1601 guests, 139 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
