Hallo all,
My 10D's internal flash pops up when it should but the camera gives almost direcly an error code 05 and can only be resetted by the power switch or juggling with the batterys.
When the flash pops up (either by hand pressing the button or by the camera itself) it makes ,after the flash has popped up, another two noises, more or less similair as when the flash is popping up.
To my understanding err code 05 means that something is blocking the flash and that the camera will try two more times to release the flash and gives after that the error code. In my case the flash pops up the first time but apparendly the camera doesn't notice that and tries it two more times (still doesn't notice the flash is already up) and gives error code 05.
Queations :thirst is my asumption of the above correct, second (apart from sending it to canon or getting an external flash) does anybody knows a remedy for this.
Thanks ,Ted.
