Thread started 16 Nov 2009 (Monday) 14:09
ABR800 & Snoot? How to make background black?
KFormus
Nov 16, 2009 14:09 |  #1
So I am trying to create a lighting situation in which my subject is slightly lit and the background is completely dark. I am having a tough time figuring out how to do this with the following equipment:
ABR800
(2) 580ex
White paper backdrop 10 feet wide
Anyone can run me through what i need to do? Do I need to make some sort of snoot? Can't see how I can do that with the ABR800 and moon unit.
5DII, 40D, 24-70 f/2.8L, 70-200 f/2.8L IS, 10-22 f/3.5-4.5, 50 f/1.8 II, 580EXII, 580EX, ABR800
k_strecker
Nov 16, 2009 14:49 |  #2
KFormus wrote in post #9025416 (external link)
ABR800
(2) 580ex
the only way to do it with white paper is to make sure ZERO light is falling on it.
You'll need a lot of room to make sure there's no bounced light filling in and making it come out grey.
It'll still be a large technical challenge, even with the snoot. It's that bouncing light which will foil your attempts fastest. Buy black cards, or black velvet, and use that as your background to give yourself a huge push in the right direction.
LoganJ
Nov 16, 2009 14:53 |  #3
I would just shoot with the white background, mask out the person in PS, and brush in the white background black.
Canon 50D w/ Grip | 17-40mm f/4L | 50mm f/1.2L | 60mm f/2.8 USM Macro | 70-200mm f/4L | 580EX II w/ Sto-Fen OmniBounce | Manfrotto 055XPROB legs w/ 488RC2 head | PocketWizard Mini TT1 & Flex TT5 |Sekonic L-358
KFormus
Nov 16, 2009 15:50 |  #4
ugh i hate masking like that. Always looks way fake. I'll use a black bg I suppose lol thx K and logan
Seanzky
Nov 16, 2009 18:56 |  #5
Make sure there's ample distance from the subject and background, light the subject and make sure nothing spills to the background.
ootsk
Joined Jan 2002
Nov 16, 2009 19:04 |  #6
Super low settings on the flash as well. Something about the fall-off ratio. If you're at f1.4 (or 2.8, or whatever) and have the flash low, by the time it gets to the background it will be the least it can be.
TMR ­ Design
Joined Feb 2006
Nov 16, 2009 19:22 as a reply to  @ ootsk's post |  #7
To achieve a pure black background you have to make sure there is separation between subject area and background and no spill from your subject area lighting.
If you have a hand held light meter the key is to make sure your background is 4 stops reflective under your incident subject area lighting.
For instance, if you're subject area lighting is giving you a reading of f/8 incident then you need to meter your background at f/2 reflective.
Robert
Player9
Nov 16, 2009 19:26 as a reply to  @ ootsk's post |  #8
I doubt that the strength of the stobes will make any difference. The critical elements are (1) the distance of the background from the subject and (2) the depth (not amount) of light on the subject. Ironically, I learned all this back in the days when I used hot lights. Then, I had to put the lights right on top of the subjects to get acceptable shutter speeds at ISO400, and I found that most of the backgrounds would go very dark regardless of the color. Unless you are using black velvet, the background should be far away from the subject (at least 12-15 feet back) and the lights need to be very close to the subject to minimize the depth of the light. Also, use flags to try to stop any light from hitting the background.
RP, 60D, RF 24-105mm f/4-7.1 IS, RF 35mm f/1.8 IS, RF 50mm f/1.8, EF-S 10-22mm f/3.5-4.5, EF-S 18-135mm 3.5-5.6 IS, EF-S 55-250mm f/4-5.6 IS, Tamron 17-50mm f/2.8, EF 28mm f/1.8, EF 50mm f/1.8, EF-S 60mm f/2.8 macro, EF 85mm f/1.8, El-100, 430ex, 220ex, Alien Bee B400 (2), Alien Bee B800 (2)
TMR ­ Design
Joined Feb 2006
Nov 16, 2009 19:31 as a reply to  @ Player9's post |  #9
It's the ratio of subject area lighting to background. Distance is a great way to increase that ratio but you can turn a background black at very close range as long as you have control over your lighting.
Robert
ootsk
Joined Jan 2002
Nov 16, 2009 20:15 |  #10
Player9 wrote in post #9027190 (external link)
Of course the strentgh of the strobes make a difference.
If you have 8 feet of separation between a subject and a white background what would darken it the most?
Camera and strobes set to light the subject at f16, or
Camera and strobes set to light the subject at f1.4?
Your comment of getting the lights very close to the subject is true, as that is needed to keep the power as low as possible.
NaKiD ­ EyE
Nov 17, 2009 03:54 |  #11
get a black background. done.
TMR ­ Design
Joined Feb 2006
Nov 17, 2009 07:27 |  #12
NaKiD EyE wrote in post #9029210 (external link)
Not true. Even with a black background you have all the same variables that will cause it to render as something other than black. One of the most common things (and popular posts) is to have a black background that is being rendered as dark gray because of spill or an improper ratio between subject area and background.
Robert
Seanzky
Nov 17, 2009 07:33 |  #13
You spill a little light on that black background and you get dark grey. So, not done. In fact, back to square one.
TriStatePhotog
Nov 17, 2009 09:03 |  #14
Black background and distance or a very far away/no background. Meaning, outside.
Matthew ­ Hicks ­ Photography
Nov 17, 2009 09:16 |  #15
IMAGE: http://www.holtsauto.com/images/products/repair-and-maintenance/paint/simoniz-spray-paint-gloss-black-hi.jpg
In all seriousness, without a fair bit of photoshop work, a white background doesn't easily turn into a black one due to how it reflects almost every bit of light back.
Calgary Wedding Photography by Matthew Hicks: www.matthicksphoto.com (external link)
2,975 views & 0 likes for this thread, 11 members have posted to it.
1421 guests, 172 members online
