Thread started 19 Nov 2009 (Thursday) 05:23
Not sure where to post this. . .
Data
Nov 19, 2009 05:23 |  #1
Hi all,
Was not sure where to post this so thought here would work.
I have a problem with my Camera, When ever I photograph a white light I see reflection in my camera. I can see it through the eye piece and then it shows in my picture.
I first noticed it when photographing street lamps which had a white light although cant find any samples on my computer.
The sample I have below shows the light reflection. Although the sample shows the light pointing directly in to the lens , it will also do the same thing when pointing at an angle.
I have tried to clean the mirror and sensor but its not changed anything.
What would be the cause and how would I go about fixing it?
Sorry for the poor photo, I took whilst testing.
Thank you.
IMAGE: http://farm3.static.flickr.com/2718/4116504525_06615d42cf_o.jpg
Canon 450d | Canon EF 50mm f/1.8 II | Canon EF-S 18-55mm IS Kit Lens | Canon EF-S 55-250mm F/4-5.6 IS | Canon EF 28-135mm f/3.5-5.6 IS USM | Raynox DCR-250 | Canon Speedlight 430EX II
sapearl
Gallery: 243 photos
Nov 19, 2009 05:35 |  #2
Are you perhaps using an inexpensive filter that is not coated? It could be a reflection off that glass.
MY WEBSITE (external link)- MY GALLERIES (external link)- MY BLOG (external link)
Artists Archives of the Western Reserve (external link) - Board
Data
Nov 19, 2009 06:40 |  #3
Nah, changed filters and lenses and same results.
sapearl
Gallery: 243 photos
Nov 19, 2009 06:57 |  #4
Hmmm..... that stumps me. Does this exact same thing happen identically with ALL of your lenses? And also with no filters on?
And does it just happen with point light sources? In other words, say you had a bare bulb lamp in your livingroom - would the same thing happen? I assume there are no smudges on the inside of the filter or anything. I'm racking my brain here.....:cry:
Data wrote in post #9042545 (external link)
philwillmedia
Nov 19, 2009 07:04 |  #5
There's no problem with your camera - or lens.
That's just lens flare.
Not a lot you can do about it except change the angle of view so the light doesn't hit at the angle that causes it.
Regards, Phil
2019 South Australian Country Press Assoc Sports Photo of the Year - Runner Up
2018 South Australian Country Press Assoc Sports Photo of the Year
2018 CAMS (now Motorsport Australia) Gold Accredited Photographer
Finallist - 2014 NT Media Awards
"A bad day at the race track is better than a good day in the office"
Data
Nov 19, 2009 07:11 |  #6
Yes, Happens with all lenses and with no filters on.
I just took this one for you to see. I changed lens and had no filter on. This one is with a 50mm
IMAGE: http://farm3.static.flickr.com/2571/4116677127_4644e8d38f.jpg
Data
Nov 19, 2009 07:12 |  #7
philwillmedia wrote in post #9042627 (external link)
If that is all it is then I can live with that.
neilwood32
Nov 19, 2009 07:15 |  #8
Just plain old lens flare.
Basically every time light hits a lens surface, it gets bent and over a series of these it can show up as flare.
Some lenses take care of it by way of coatings, others by using different lens materials. Others just dont handle it well at all.
Having a camera makes you no more a photographer than having a hammer and some nails makes you a carpenter - Claude Adams
Keep calm and carry a camera!
sapearl
Gallery: 243 photos
Nov 19, 2009 09:01 |  #9
Best lenses I ever had were those made by Zeiss when I shot Hasselblad. Just about every one of those you could virtually shoot into the sun and get wonderful, flare free results.
Then I switched to Canon; some are terrific and give wonderful results, some less so.....
neilwood32 wrote in post #9042679 (external link)
Just plain old lens flare.....Some lenses take care of it by way of coatings, others by using different lens materials. Others just dont handle it well at all.
Data
Nov 19, 2009 14:59 |  #10
Ok, I went out tonight and just got in.
I dont think is lens flare.
IMAGE: http://farm3.static.flickr.com/2773/4118359892_865a92ef78.jpg
I have had my Camera 1 year and believe the warranty has JUST ran out so need to try see what's up with it.
highbarger
Nov 19, 2009 15:16 |  #11
Data wrote in post #9045384 (external link)
Again, this is NOT a warranty issue with your camera. Light reflecting on the elements of your lens is the cause.
sapearl
Gallery: 243 photos
Nov 19, 2009 22:05 |  #12
Agreed. Somehow it's the technique you're using.
highbarger wrote in post #9045512 (external link)
Data
Nov 20, 2009 01:18 as a reply to  @ sapearl's post |  #13
Ok, Thank you all that responded.
neilwood32
Nov 20, 2009 07:17 |  #14
As Highbarger said - light reflecting within the lens elements - it does sometimes happen when taking dark photos with very bright light sources.
Only answer that i can come up with is take of any filters you are using - the more glass the higher the chance for this (it is quite often between the filter and the front element).
Other than that - be prepared for lots of PP work.
Martin ­ Dixon
Slit-scan project master
Gallery: 59 photos
Joined Sep 2009
Nov 20, 2009 18:43 |  #15
I can hardly believe the last image, I tried really hard with a couple of my lenses and I had major trouble getting anything noticable from a bright LED or normal lightbulb. Yours seems perfectly reflected through the centre point. Must be the lens but very odd. What lens were you using?
flickr (external link) Editing OK (external link) www.slitcam.com (free slit-scan utility) (external link)
2,515 views & 0 likes for this thread, 9 members have posted to it.
989 guests, 123 members online
