Thread started 19 Nov 2009 (Thursday) 17:01
Mallard in Flight
Bill ­ Boehme
Enjoy being spanked
Gallery: 39 photos
Nov 19, 2009 17:01 |  #1
One of my first decent BIF shots, but the group of mallards were 120 yards away and going towards the sun which was low in the sky. As a result of the distance these are 100% crops which is generally not a good idea.
The lens used was my EF400mm 5.6L on my 7D. These are ISO 800 images. Other shooting information -- shutter speed was 1/1600 second and aperture was f/8. I used single point expansion for tracking and focus with the AF-ON button only. Since my holding is not very steady, I used a tripod with a Wimberly Sidekick gimbal mount. My good tripod is broken so I was using a cheap limber-legged tripod that shakes like a leaf in the breeze.
The first image has minimal processing -- I accidentally used the ACR defaults for tonal adjustments in the basic tab and used my nominal sharpening values (45, 0.7, 25, 25). The only noise reduction that I ever apply during RAW conversion in ACR is color noise reduction and very little in this case -- 28. I never use Luminance NR because it softens images. In Photoshop, I converted the profile from ProPhotoRGB to sRGB, cropped the size, and converted to 8-bits. I am really impressed with ISO 800 in good light.
In the second version, I had to use 400X enlargement in ACR to see the effects of sharpening, but I learned a lot about my 7D images while doing so. I found that using a radius of 0.5 is by far the best and that I got the best results by keeping the Detail slider at 25 or less -- above 30, "crumbly" artifacts started appearing rather quickly. In Photoshop, I applied a very tiny bit of exposure adjustment and did an unsharp mask output sharpening of 50, 0.3, 0. I did not think that it needed noise reduction, but I gave Neat Image a try with very light adjustments, but it seemed to cause more harm than good so I backed out of it. In the end, I don't think that I gained a great deal by the extra processing.
Atmospheric haze in images? Click for Tutorial to Reduce Atmospheric Haze with Photoshop.
Gear List .... Gallery: Woodturner Bill (external link)
Donate to Support POTN Operating Costs
Bill ­ Boehme
Enjoy being spanked
Gallery: 39 photos
Nov 19, 2009 17:18 |  #2
Here are the lead ducks from the same image as the previous post. This one uses a very tiny bit of Neat Image NR and sharpening.
dbriz
POTN MILLIONAIRE
Nov 19, 2009 17:19 |  #3
Nice shots Bill, I particularly enjoy the "double"... good shooting.
db
canonloader
Gallery: 6 photos
Nov 19, 2009 17:30 |  #4
I have noticed the wrinkles in my shots too, when I do almost any cropping of the image. Not sure if thats from the reducing algorythm in CS3 or what, but the 7D images don't hold up as well as my MkIIN or 40D images did. Which makes no sense to me.
Mitch- ____...^.^...____
artyman
Sleepless in Hampshire
Gallery: 17 photos
Nov 19, 2009 18:09 |  #5
Nice in flight shots
Ken
sparker1
Nov 19, 2009 18:18 |  #6
Great captures, Bill.
Bill ­ Boehme
Enjoy being spanked
Gallery: 39 photos
Nov 20, 2009 02:51 as a reply to  @ sparker1's post |  #7
Thanks for the comments db, Mitch, Ken, and Stan.
Mitch, can you clarify the "wrinkles" that you mentioned? I suspect that you are talking about the feather pattern on the duck's back, but that is just a wild guess.
Bill ­ Boehme
Enjoy being spanked
Gallery: 39 photos
Nov 20, 2009 15:27 as a reply to  @ Bill Boehme's post |  #8
I forgot to mention earlier that I was not quite happy with the beta profile for the 7D that is presently used in Adobe's DNG Converter as well as in ACR and Lightroom (they all use the same RAW conversion engine). Because of that, I created my own 7D profile (actually a group of profiles) and the images seen above were done using my custom 7D profile. The profile that I created tends to have less noise than the beta profile because, relatively speaking, it shifts tonal values downwards while the beta profile seems to shift darker tones upward.
One other thing that I have found different about 7D images is that color balance in the dark areas is slightly different than in the highlight areas, therefore, for the first time I am now using the Split Toning tab in ACR to tweak the color of the shadows. For my camera, I leave the highlights adjustments at 0, 0. I set the balance to +90 and for the shadows, I set hue to 50 and saturation to 45. Different lighting situations require some tweaking of these numbers.
Mitch, there was no rescaling downwards of the images. They are 100% crops. Here is what they looked like in the context of the whole image.
I also decided to see what it would look like using DPP to do the RAW conversion and processing and thought that it looked rather dismal by comparison (see below).
canonloader
Gallery: 6 photos
Nov 20, 2009 15:42 |  #9
Bill Boehme wrote in post #9048785 (external link)
Remember the Little Chickadee thread of mine from the other day? Look at those shots close. All of them have the wrinkles right next to the bird, like a little layer around them. Compression artifacts, I think from resizing after some small cropping. I also don't like the noise from even a small crop, then sized to 1000x667, so I ran the blur tool over the clear background parts. Not the bird or wood stuff.
Bill ­ Boehme
Enjoy being spanked
Gallery: 39 photos
Nov 20, 2009 16:29 |  #10
canonloader wrote in post #9052035 (external link)
Thanks, Mitch. I guess that I missed seeing your chickadee thread. Those are some really fine images. I have used the technique that you describe on a few occasions, but not as often as I should on bird images. For most other type of less critical images such as landscapes, it is not a significant issue. The image above were not resized and they looked the same before I cropped them. I have also seen the same thing in DPP images. It is the result of two things:
  • The first thing that causes this is the RAW converter itself. The first part is the demosaicing -- as it reconstructs a color image by interpolating data between adjacent photosites, edges in the image becomes rather soft. The RAW converter uses edge detection algorithms to help reduce color smearing across edges that it is able to identify, but in so doing, the process introduces artifacts of their own which is most of what you see in these images.
  • The other thing that will cause a problem is edge sharpening using the unsharp mask. Downsizing an image frequently make it a bit soft along the edges and typical practice is to add a bit of USM. However, for things like bird images with their fine feather details, USM can easily make things look much worse.
  • One other thing. Sometimes people say that they did not sharpen an image. In actuality, there is not such thing as an image without some sharpening being applied automatically. And, we really would not want one with no type of sharpening done during RAW conversion.
Separating the background and blurring it would be easy in the above images. I have a book of down and dirty Photoshop tricks and one that can work nicely is to separate the subject from the background and then shrink the background by a few pixels -- now the subject will hide the edge artifacts. Also, showing something at 100%, as I did, is not normally a good idea, but I suppose that I was just gloating over my 400/5.6 lens. I like it so much that I may even buy it a box of chocolates. :D
canonloader
Gallery: 6 photos
Nov 20, 2009 16:41 |  #11
What I am saying though, is I never got these compression artifacts form MkIIN or 40D RAWs. I use the same editing workflow, except for exporting a tiff from DPP. I'm going to use DNG on one and see what happens.
jgrussell
Looking around nervously
Nov 20, 2009 16:44 |  #12
Nice shots, Bill, and they'd be better still with some noise reduction on the background only (layer it and protect the bird).
-- jgr
Bill ­ Boehme
Enjoy being spanked
Gallery: 39 photos
Nov 20, 2009 17:20 |  #13
jgrussell wrote in post #9052420 (external link)
Thanks, Judy. I may give it a try.
patlannon
Nov 20, 2009 17:24 |  #14
Bill, at 100% crops these shots are very passable, the slight noise in the background is non-existent on my computer screen.
Pat,
West Seneca, NY
Gear, 5D3, 7D, Glass, All Canon, 8-15mm L, EFs 15-85mm, EFs 60mm Macro, EF 100mm L Macro, EF 24-105mm L, EF100-400 L.
Bill ­ Boehme
Enjoy being spanked
Gallery: 39 photos
Nov 20, 2009 18:56 |  #15
canonloader wrote in post #9052409 (external link)
That was my initial impression when comparing the images to the XTi images before I shifted my paradigms to realize that I am seeing a magnified view compared to the other models, especially the 1D MkIIn. Using the same lens means that the 7D images will appear less sharp because of the magnification caused by greater pixel density and then you throw in a few edge artifacts on top of that.
These earlier models did not have full coverage sensors so they are, in essence, taking point samples and expanding what it sees out to the edge of the adjacent pixels. This is a form of aliasing that effectively hides or masks out a lot of detail and makes an image appear smoother. So, everything has its good and bad points.
As far as edge artifacts are concerned, they are a fact of life regardless of what RAW converter you use and the camera model makes no difference. Compression artifacts are not a result of downsizing, but happen when the image is converted to a JPG. However, all downsizing algorithms use algorithms to improve edges in order to avoid stair-stepping. The artifacts appear in all images -- I have seen them in images made with several different camera models because it is NOT the camera (unless you shoot in-camera JPG images), but the editing software that creates it. Here is a magnified example of edge artifacts from my XTi. The artifacts are still noticeable at normal viewing size. Something else -- the lower pixel density and its point sampling which aliases details causes a blown up view to look very crumbly despite having a very sharp lens. If you click on the image, you can se a normal sized image that will show how the edge artifacts look.
 (external link)
A couple of people that I know have said to me that they prefer in-camera JPG images to RAW because of the IQ. I guess that they did not know that all digital cameras shoot in only one mode -- RAW, but some don't make the RAW version available.
3,415 views & 0 likes for this thread, 8 members have posted to it.
Mallard in Flight
1181 guests, 137 members online
