chris250 wrote in post #9064494
What should I be looking for in a telescope for ability to attach my camera.
That's pretty easy to answer really. All you need is a T-Ring, which is specific to your camera, (attaches like a lens would), and a T-Adapter, which is more generic, and at one end screws into the T-Ring, then at the other end slides into the telescope focuser. The T-Adapters are generally 1.25" or 2", which are the main standard sizes. 2" is best, but if the scope's only got a 1.25" focuser then that'll work too.
And that's about it really. However, Newtonian Reflectors, like the one you linked above, are not ideal for Astrophotography. I started with one much like that, and simply couldn't get anywhere near focused with my DSLR, so I sold it and moved to Refractors. Much more suitable.
Driven mounts aren't essential for lunar and planetary imaging, since exposure times are generally quite fast, but they're useful. For deep sky imaging at high focal lengths a driven mount is the most important thing.
I've got an EQ5 mount and a 70mm ED Refractor. Together they're worth around £400-£500 I guess. Not a bad setup for half-decent moon and planet shots, and pretty good for deep sky imaging too. My personaly recommendation would be something along these lines.
