Thread started 23 Nov 2009 (Monday) 06:20
Damaged Sensor?
betebete
Nov 23, 2009 06:20 |  #1
I have a problem with my camera, i get these wierd lines running through my pictures, it only happen when the picture is dark.
http://bildr.no/view/5​31754 (external link)
It goes through the top (landscape) and the left side.
Have anyone had this problem before, or know how much it would cost to fix it?
Its a canon 5d Mark 1, no warranty :(
http://btfoto.no (external link)
trancerem
Nov 23, 2009 06:25 |  #2
looks ****ty to me :(.
might consider adress to closest canon service.
Nikon :: D750 / 16-35 4 VR / 50 1.4 / 85 1.4 / SB900
drdiesel1
Gallery: 86 photos
Nov 23, 2009 06:26 |  #3
betebete wrote in post #9066149 (external link)
Is that with flash. Maybe your shutter sync speed is to high or your shutter is failing. I don`t think it a Sensor issue.
Nikon D810 Nikon 50F/1.4G - Nikon 70-200F/2.8II
Canon 5DMKIII - Canon 24-105F/4L
Winck
Nov 23, 2009 06:43 |  #4
Are you using Cactus triggers with the 5D?
Some models has issues with the 5D mrk1
http://www.flickr.com …/72157603230295​239/page2/ (external link)
Knud
drdiesel1
Gallery: 86 photos
Nov 23, 2009 06:49 |  #5
Winck wrote in post #9066214 (external link)
Knud
This guy did some modification work to cause it.
so I did the cactus radio trigger mod (antenna on the transmitter) and to my surprise I discovered the following effect:
the bands occur not only when the transmitter is mounted on the hotshoe, but also when it is near the camera.
the affected sensor was the full frame cmos in canon 5d
the smaller sensor of canon 20d was also affected, but to a lesser extent, (bands are clearly visible after boosting the raw brigntness adjustment up a one stop. see here
the mod I did was basically aKuster (external link) based mod - the difference is that I used a copper TV wire instead of an antenna - so it would be cool is someone with that mod and a 5d could check if the dedicated 433 mhz antenna mod also produces this effect.
the good news is that it is not a permanent damage - at least not after about 200 exposures,
anyway - for me that make the mod unacceptable, even if I finally reached a 99% reliability in studio conditions.
Winck
Nov 23, 2009 06:53 |  #6
Found a better link. Apparently, it's not only the modded ones
http://www.fredmiranda​.com/forum/topic/75898​4 (external link)
Check out the banding in http://photodecal.org …/main.php?g2_it​emId=46122 (external link)
Looks pretty much the same as the OP's to me?
Knud
Markitos
Nov 23, 2009 07:23 |  #7
Another question, just in case--did you try a different CF card?
|Fuji X-E2|Fuji X-E1|Fuji 18 f/2|Fuji 35 f/1.4|Fuji 60 f/2.4 macro|Fuji 18-55 f/2.8-4|Fuji 55-200 f/3.5-4.8
http://www.newschoolof​photography.com/forum/ (external link)Where I Hone My Skillz (external link)
Where My "Serious" Stuff Is (external link)
betebete
Nov 23, 2009 09:51 |  #8
Markitos wrote in post #9066337 (external link)
Yes i have tried different CF's..
ABout the cactus issue, that MIGHT be the problem.. I used a cactus for that shot there, but i cant remember if i used cactus on the other shots.. I might have to do some testing again :)
The cactus is a friends, so i dont always use it..
Thanks for the info, i will come back with more!
alt4852
Nov 23, 2009 09:53 as a reply to  @ betebete's post |  #9
looks like RF interference to me.
5D4 | Z21 | 35L2 | 50L | 85L2 | 135L
betebete
Nov 23, 2009 10:46 |  #10
My problem looks very much like the ones described in the other posts.. Thanks guyes, you saved me alot of money :P
Winck
Nov 24, 2009 02:27 |  #11
betebete wrote in post #9067219 (external link)
No. Not really. Can't you feel that burning, allmost intolerable urge to buy some Pocket Wizards instead. You know you want them. You neeeed them...:cool:
Knud
Sean
Nov 24, 2009 11:10 |  #12
Winck wrote in post #9071764 (external link)
Knud
I'll tell you I am getting PW's when I get my lighting setup. I've read enough about the quality difference between Ebay triggers and others. I may however be shooting PCSync for the next while.
Canon 50D - 17-55mm F2.8 IS - 300mm F4L IS - 70-200mm F4L IS - 50mm F1.8 - 580EX II & 430EX - Full Gear Listing
Flickr (external link) - C&C Always welcome.
2,185 views & 0 likes for this thread, 7 members have posted to it.
Damaged Sensor?
1030 guests, 106 members online
