I am looking to get a len's hood for EF-S 18-55mm and EF-S 55-250mm.
What do you think of this hood: http://www.amazon.com …ics&qid=1259021804&sr=8-1![]()
Or, what would you suggest?
Thank you!
Nitecruiser Mostly Lurking 17 posts Joined Nov 2009 More info | Nov 23, 2009 18:19 | #1 I am looking to get a len's hood for EF-S 18-55mm and EF-S 55-250mm.
LowriderS10 Cream of the Crop 10,170 posts Likes: 12 Joined Mar 2008 Location: South Korea / Canada More info | Nov 23, 2009 19:00 | #2 I think hoods are the second most overpriced crap Canon sells (tripod collars being the #1 rip-off)...so if it fits, go for it. It's just a piece of plastic... -=Prints For Sale at PIXELS=-
tgara Goldmember 2,336 posts Likes: 8 Joined Sep 2007 Location: Connecticut, USA More info | I would go with the OEM hoods for each of your lenses. I know they are expensive, but they are specifically designed for the particular focal lengths and will not block any of the view. Third party hoods may not be as precisely constructed in this regard. EOS 5D Mark III
LeonidPhotography Senior Member 715 posts Joined Mar 2009 Location: Cupertino, CA More info | Nov 24, 2009 20:12 | #4 Do not get that hood. You will not like it. It screws on like a filter and can vignette. You can get a after market that clips in just like a stock hood, much better then the screw type. Canon 6D, Canon 50mm 1.8 STM
sparkin Cream of the Crop 6,522 posts Likes: 14 Joined Nov 2006 Location: Lex, Ky More info | Nov 24, 2009 20:18 | #5 LowriderS10 wrote in post #9069884 I think hoods are the second most overpriced crap Canon sells (tripod collars being the #1 rip-off)...so if it fits, go for it. It's just a piece of plastic... No kidding! These things should be thrown in for free with all lenses.
msowsun "approx 8mm" More info | Nov 25, 2009 03:19 | #6 Those "Pro Digital" lens hoods screw into the filter threads. Both of your lenses have rotating front elements and filter threads. Every time you focus the hood would rotate and be out of alignment. Mike Sowsun / SL1 / 80D / EF-S 24mm STM / EF-S 10-18mm STM / EF-S 18-55mm STM / EF-S 15-85mm USM / EF-S 55-250mm STM / 5D3 / Samyang 14mm 2.8 / EF 40mm 2.8 STM / EF 50mm 1.4 USM / EF 100mm 2.0 USM / EF 100mm 2.8 USM Macro / EF 24-105mm IS / EF 70-200mm 2.8L IS Mk II / EF 100-400 II / EF 1.4x II
SkipD Cream of the Crop 20,476 posts Likes: 165 Joined Dec 2002 Location: Southeastern WI, USA More info | Nov 25, 2009 07:19 | #7 There's absolutely no way that a single hood can be anywhere close to optimum for all the focal lengths listed in the advertisement (link in post #1). The photographs in the advertisement showing flare and no-flare in an image are, at best, stretching the truth to the limit for that hood. Skip Douglas
tvphotog Cream of the Crop More info | Nov 25, 2009 08:56 | #8 Many of these knockoff hoods do not have fabric flocking on the inside to absorb and not reflect light. The Canon's do. Look at some of the Chinese knockoffs, some do have the flocking. If you do, make sure they are the same dimensions at the petals as the Canon for your lens. Jay
canondslr Senior Member 944 posts Joined Aug 2006 Location: USA More info | Nov 26, 2009 06:14 | #9 or you can buy used original Canon hood, could save you around $10 per hood.
RPCrowe Cream of the Crop More info | Nov 26, 2009 22:58 | #10 Generalization and a misconception... tgara wrote in post #9070635 I would go with the OEM hoods for each of your lenses. I know they are expensive, but they are specifically designed for the particular focal lengths and will not block any of the view. Third party hoods may not be as precisely constructed in this regard. You have the following lenses which were designed for full frame cameras: EF 24-70 f2.8L / EF 70-200 f2.8L IS / [COLOR=black]EF 17-40 f4L / EF 50 f1.4 / 85 f1.8. See my images at http://rpcrowe.smugmug.com/
SkipD Cream of the Crop 20,476 posts Likes: 165 Joined Dec 2002 Location: Southeastern WI, USA More info | Nov 27, 2009 04:52 | #11 RPCrowe wrote in post #9089072 You have the following lenses which were designed for full frame cameras: EF 24-70 f2.8L / EF 70-200 f2.8L IS / [COLOR=black]EF 17-40 f4L / EF 50 f1.4 / 85 f1.8. The Canon hoods for these lenses were designed "not to block any of the view" OF A FULL FRAME CAMERA. The OEM hoods for these lenses are larger than necessary and will not provide the optimum flare protection when used with any of the above lenses on your 1.6x camera. Your suggestion is misleading, in my opinion. The "larger than necessary" statement is only true if you are referring to the diameter. If you maintain the diameter of the Canon hoods, you would actually need to extend the length of the hoods to make them optimum for a smaller format. Otherwise, you could reduce the diameter of the hoods to optimize the performance on an APS-C camera. Skip Douglas
RDKirk Adorama says I'm "packed." More info | Your suggestion is misleading, in my opinion. The "larger than necessary" statement is only true if you are referring to the diameter. If you maintain the diameter of the Canon hoods, you would actually need to extend the length of the hoods to make them optimum for a smaller format. And I don't know why none of the knock-off companies hasn't seized on the idea of producing hoods specifically for 15x22mm cameras. They're already making copies of the Canon hoods--all they'd need to do is extend those 1.6x and market them especially for the cropped cameras. TANSTAAFL--The Only Unbreakable Rule in Photography
msowsun "approx 8mm" More info | Nov 29, 2009 07:27 | #13 This website shows "Alternate" hoods that can be used on crop cameras: http://blog.davidburren.com …ate-canon-lens-hoods.html Mike Sowsun / SL1 / 80D / EF-S 24mm STM / EF-S 10-18mm STM / EF-S 18-55mm STM / EF-S 15-85mm USM / EF-S 55-250mm STM / 5D3 / Samyang 14mm 2.8 / EF 40mm 2.8 STM / EF 50mm 1.4 USM / EF 100mm 2.0 USM / EF 100mm 2.8 USM Macro / EF 24-105mm IS / EF 70-200mm 2.8L IS Mk II / EF 100-400 II / EF 1.4x II
| Latest registered member was a spammer, and banned as such! 2799 guests, 173 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
