Thread started 23 Nov 2009 (Monday) 18:44
Heat shimmer question relative to focal length
chupacabra31
Nov 23, 2009 18:44 |  #1
So It occurs to me that using a extender will magnify heat shimmer more so I will have to still be close to the subject to get a clear image. So then what advantage does a 1.4x tc offer other then getting you closer on say a cool day or certain time of day? What temperature limits does a 1.4x tc or higher focal length lens have? For instance lets say its 80F out and I have a 500 f/4 that I want to use the 1.4x tc or a 2x tc on. Will the 80F nessecatate the need to get that much closer? Its all very confusing the whole heat shimmer thing. I guess what I am wondering is at what temp/conditions should I not even bother with a 1.4x tc and for that matter a prime lens?
Thanks in advance for any help!
hollis_f
Nov 24, 2009 03:39 |  #2
There's an awful lot more to heat haze than the air temperature - there's the intensity of the sunlight, the type of surface between you and your target, the difference in temperature between the surface and the air just above it, wind speed. I was on the north Norfolk coast in February this year where the air temperature was around 10ºC (around 50º F) but there was bright sunshine. The heat haze meant that anything more than 50m away wasn't suitable as a target. I've also been out on overcast days when the temperature has been very high and there's no heat haze.
When heat haze is a problem then the only solution is to minimise the amount of air between you and your target. A TC will still help if your target is small.
Frank Hollis - Retired mass spectroscopist
Give a man a fish and he'll eat for a day. Teach a man to fish and he'll complain about the withdrawal of his free fish entitlement.
Gear Website (external link)
philwillmedia
Nov 24, 2009 04:06 |  #3
heat haze...mmmm, I love heat haze.
Don't try to fight it. Use it to your advantage
You can end up with some great effects
Here are a couple of images from a race meeting earlier in 2009.
Temps around mid to high 30'sC
Regards, Phil
2019 South Australian Country Press Assoc Sports Photo of the Year - Runner Up
2018 South Australian Country Press Assoc Sports Photo of the Year
2018 CAMS (now Motorsport Australia) Gold Accredited Photographer
Finallist - 2014 NT Media Awards
"A bad day at the race track is better than a good day in the office"
SkipD
Joined Dec 2002
Nov 24, 2009 05:19 |  #4
As Hollis said, heat haze in an image really has nothing to do with a lens' focal length, per se. It has everything to do with what's in between you and your subject (that can heat the air and cause the haze effect) and the distances involved.
Longer distances between the camera and the subject involve more air that could be "wiggling" due to heat haze. You can see the effect of heat haze with or without a camera. You can see it with your naked eye, though it may not be quite as apparent relative to the scene in front of you. The heat haze will affect what you see through binoculars or a rifle scope as well.
Don't confuse what I'm saying about heat haze and distances with my descriptions (elsewhere) of perspective control, although perspective is controlled by controlling the distances between elements of the scene and the camera.
Skip Douglas
chupacabra31
Nov 24, 2009 07:24 |  #5
hollis_f wrote in post #9071908 (external link)
Oh okay sorry for being a little ignorant. Your right. Thanks for putting it into perspective for me. I was wondering what is an easy method to know if I should be within say 50m or if I can get away with less? I have noticed that I cannot really detect the softness haze causes on my 1dMKIIs tiny LCD. I shoot in Raw as well. Thanks again!
spkerer
Nov 24, 2009 14:03 |  #6
Here's another heat-haze effect. You can see it on part of the picture but not on the other part. In this case the source of the heat is obvious - it was actually a pretty cool day.
IMAGE: http://photos.kusterers.net/img/v4/p48469376-4.jpg
Leesburg, Virginia
http://photos.kusterer​s.net (external link)
FlyingPhotog
Cream of the "Prop"
Nov 25, 2009 02:14 |  #7
Somtimes it adds a little "texture" to the image...
But the effect begins to fade as the sun begins to set:
Jay
BobOh
Nov 25, 2009 10:28 |  #8
FlyingPhotog wrote in post #9078105 (external link)
And sometimes it makes it damn near surrealistic:
https://photography-on-the.net/forum/showthre​ad.php?t=475747
Regards,
Bob
Gear: 40D, 7D, EF 100-400L, EF 28-135, Speedlight 580EX and other stuff.
Flickr: http://www.flickr.com/​photos/bobbolew/ (external link)
hollis_f
Nov 26, 2009 11:17 |  #9
Yes, I'll agree that it can really add to an image -
IMAGE: http://photos.imageevent.com/frankhollis/trips/santapod/huge/Santa%20Pod%2010-09-06%20017%20.jpg
5,158 views & 0 likes for this thread, 7 members have posted to it.
2852 guests, 138 members online
