Thread started 24 Nov 2009 (Tuesday) 14:20
Question about stacked TC's... Only 1 stop lost?
Invertalon
Nov 24, 2009 14:20 |  #1
I just received my second Tamron TC (1.4x) Pro today. I stacked them, expecting to be at f/8 for shooting, since I would loose two stops of light. To my surprise, it was limited to f/5.6... So I thought ok, the second must not be reporting. So I took test shot at f/5.6 and exposure looked fine. Put it up to f/8 and it looked identical (although greater field of depth). Also, AF is working fine, although a little slower to lock on. But it seems to be accurate once it does lock.
Is there something I am missing here with this? Why is not the f/5.6 dark or show any signs of flaw? I was expecting to have to shoot at f/8 but it looks like I may not need to...
Appreciate the help!!
-Steve
Facebook (external link)
mbellot
"My dog ate my title"
Nov 24, 2009 14:24 |  #2
IIRC only the TC connected to the camera is "counted" when the minimum aperture is figured (crazy, but pretty sure its true).
EDIT: Since metering is TTL (through the lens), it doesn't matter what aperture the body "thinks" its at, the metering system compensates for reality.
Invertalon
Nov 24, 2009 14:32 |  #3
Ohhh ok! I just tested it and you are correct. With 1TC at f/5.6 I get shutter speeds of 1/10, and with 2 TC at f/5.6 I get 1/4.
Appreciate it, thank you!
-Steve
322 views & 0 likes for this thread, 2 members have posted to it.
2852 guests, 138 members online
