Thread started 25 Nov 2009 (Wednesday) 01:07
Using a gray card outside?
alexandros
Nov 25, 2009 01:07 |  #1
Hi guys and girls,
Quick (newbie) question - when shooting sports photography (in this case I'm shooting water sports) does it make sense to use a gray card?
I am still getting my head around the use of a gray card (hence such a basic question).
Appreciated :)
ironchef31
Nov 25, 2009 01:44 |  #2
Welcome to the forum
Using a gray card would not hurt. At least you will have a baseline for exposure and white balance.
Ken
30D, 18-55mm, nifty 50, 17-55 F2.8 IS, 70-200 F2.8 IS
I tried to bounce my flash off the ceiling once. Left a mark on the ceiling and broke my flash.
alexandros
Nov 25, 2009 01:58 as a reply to  @ ironchef31's post |  #3
Thanks for such a quick reply.
So my work flow would go something like this:
1) I would take a photo with someone on the boat holding up the gray card.
2) I would shoot the wakeboarders. Let's say it is a perfect day and I plan to pan my shots and decide on say, shutter 1/30 with f/22, closing down the aperture as much as needed to prevent over exposure and perfectly expose.
3) I would then go home, open up Photoshop and load my gray card example into curves and I am away!
Does this sound right?
:D
alexandros
Nov 25, 2009 02:13 |  #4
Apologies I just realised I have posted in this wrong forum. Admin please move to correct forum !
lespaulowner
Nov 25, 2009 05:59 |  #5
If anything I don't go into the talk forums THAT much. And here I just learned what gray cards are. Thanks!
Antonio
I'm a level 14 photographer who can't defeat the Paintball Gym leader known as Gary Baum until I get the 300mm 2.8L IS II USM stone.
hegi
Nov 25, 2009 06:50 |  #6
My grey card workflow indoors is no different from outdoors.
Whitebalance:
1) Put the card in a place which is representative for the lighting in the shots you are going to take. Sometimes this is the model holding it up, sometimes this means putting it on the ground close to the playing field.
2) Take a blurred (camera exposure full auto mode ("P"), zoomed to fill frame, manual out of focus) picture of the grey card in said lighting to use it for
a) automatic, in-camera, custom WB
or b) use it in post processing for WB readjustments
Exposure:
3) Point your camera again at the card. Get a rough measure for exposure starting values. Read: Point your camera to the card, spot metering, adjust arpeture/shutter/ISO to your needs and until the in camera meter shows proper exposure.
4) Put the card back into your bag and take a shot with settings acquired in 3) - read the RGB histogramm and watch for any additional adjustments you will have to make to fine-tune exposure.
This is MY workflow and may vary from others. Having the grey card will give me starting values for either WB and exposure, which will normally be further adjusted either in post (WB) or with a few test shots (exposure).
In the end: just take the picture. :-)
7D · 50D · SIGMA 30MM f/1.4, CANON 85MM f/1.8, CANON 17-55MM f/2.8, CANON 70-200mm f/2.8 IS · SPEEDLIGHTS, ELINCHROM SKYPORTS AND OTHER LIGHTING STUFF · MANFROTTO 055XPROB, 488RC2 · LOWEPRO Classified Sling 180 AW · FLICKR (external link) · WEBSITE (external link)
doodie889
Nov 25, 2009 11:36 |  #7
I always use it.
Shoot just for fun.
SnapLocally.com
Nov 25, 2009 12:14 |  #8
I use a coffee filter over the lens and aim it at my light source.
www.SnapLocally.com (external link)
2,437 views & 0 likes for this thread, 6 members have posted to it.
2837 guests, 160 members online
