richardwu wrote in post #9086704
Griptape -
What did you do to get the ground to look as it does? Or if you don't mind, could you share what you did in your go at the PP?
The ground looks as it does from my first step; Duplicate the background layer, convert to black and white to my liking, and change the layer to "multiply" (which will change the layer back to color, but give you a semi-negative on some parts of the image, and give an overall much darker look). Then, using a layer mask, I masked out the car to my liking. Then I flattened the layers, and used a small dose of a plug-in called "Topaz Adjust", which can bring out a lot of detail (generally too much, so I lowered the opacity on that layer to around 40%), followed by noise reduction (Nik Dfine specifically, as Topaz Adjust can add a lot of unwanted noise). Then a healthy amount of dodge and burn, focused mainly on the car. Then I repeated my first step again (B&W, set layer to Multiply), but this time I used the layer mask to reveal the entire previous layer, and just used the white paint brush for a little bit of vignette on the corners.
