Thread started 27 Nov 2009 (Friday) 17:21
Breaking light bulbs
lavanut
Gallery: 102 photos
Nov 27, 2009 17:21 |  #1
For some reason, I had an inclination to try to get some shots of light bulbs breaking using the sound trigger I had to fire the flashes. It took a total of sacrificing 10 bulbs this initial round, but I came up with these 2 as the best of the bunch. I just thought I'd share them for anyone interested.
Oddly enough, dropping the bulb from a height of about 4' onto a concrete floor didn't generate enough force to break the bulbs. I had to throw them onto the floor to get them to break. The main trick turned out to be throwing the bulbs at the spot where I'd pre-focused the shot. :)
rrdjserv@earthlink.net
Nov 28, 2009 16:21 |  #2
Cool shots! f/11.0 seems to work great. What did you use for light?
I have 6 burned out bulbs waiting to be broken. I haven't decided whether to drop them, shoot them with my pellet rifle or hit them with a hammer.
Sigma 500mm f/4.5, Canon EOS 7D, Canon T1i, Canon 300L f/4 IS, Canon 100mm macro, Tamron 17-50, Kenko extension tubes, Canon 580 Speedlite
--Rick
lavanut
Gallery: 102 photos
Nov 28, 2009 17:42 |  #3
rrdjserv@earthlink.net wrote in post #9097596 (external link)
I used 2 speedlights on 1/64 power for the lighting. One day I'll try the pellet gun approach on some things, but I'll probably need an assistant to help with that. I don't want the pellet gun itself setting off the trigger. :)
BTW, I got a 4 pack of basic bulbs at Lowe's for 78 cents. It was worth it to get a couple of packs. I may have to go buy some more when I want to play again. I've switched to compact fluorescent for most lamps in my house now. Those might be fun to shoot when they burn out.
MrContact
Nov 28, 2009 18:19 |  #4
I'm gonna have to try this out, very nifty idea!
Perhaps a shot where the bottom of the bulb is weighted so it lands first and the glass may shatter downward...
So exciting.
flickr (external link) ~|~ http://aperturebacon.c​om (external link) ~|~ Gear List ~|~Special Flickr  (external link)
Imeddy
Dec 03, 2009 21:47 |  #5
lavanut wrote in post #9097965 (external link)
I have not read this whole thread yet but one thing you can try to experiment with instead of light bulbs are balloons. Shoot the balloons with the pellet gun and see what it's like. Then see what happens with water balloons. That sounds like soo much fun. After you get the technique down with the balloons, then you can finish off the light bulbs any way you want. Just my little thought.
ImEddy
Michael_B
Joined Sep 2009
Dec 20, 2009 08:26 |  #6
The thought of the glass shards scratching my lens terrifies me...not touching this one.
My Gallery (external link)
50D, 18-55 IS, 70-200 f4L[COLOR=black], 430EX II, BG-E2N, 200-400 IS USM L w/1.4x..thats right, getting ready.
firstclass
Dec 24, 2009 15:21 |  #7
xs5875 wrote in post #9232285 (external link)
Filter? None of the shards would be heavy/fast enough to break through a filter I'd think, especially if it's a glass filter.
lavanut
Gallery: 102 photos
Dec 24, 2009 16:53 |  #8
Thanks for the concern, but my lens was fine. There was some dust stirred up, but a little cleaning and air blowing got rid of that. As firstclass said, the broken pieces weren't going fast enough to do damage, plus I was far enough away. I could have been further, but this was a test of the concept as much as anything else. I'd never really had a chance to test the sound activated flash trigger, so this was something to play with.
Balloons are next, and I will most likely be further away on those since that stuff will scatter more than the light bulbs. :)
canonloader
Gallery: 6 photos
Dec 28, 2009 15:54 |  #9
I worked construction for years, and once worked a job where we were demolishing a building. It had overhead lightbulbs in sockets all down this long hallway. As we went out for the last time, I had a piece of lathe, a 1" wide by 3/8", by 4 feet or so and as I walked along, I just whacked those bulbs out.
You'd be surprised. I didn't get any glass on me and it was pretty interesting to do, cause the filiments were hot and when the glass broke, they flared up. Just saying. ;)
Mitch- ____...^.^...____
4,401 views & 0 likes for this thread, 7 members have posted to it.
1586 guests, 138 members online
