Thread started 27 Nov 2009 (Friday) 18:58
UV Filter stuck...
Valjoy
Nov 27, 2009 18:58 |  #1
Any suggestions for a 'stuck filter'.....its on my 17-55 so I dont want to force it too much. Its a HOYA filter.
It looks like it is sitting on the lens properly, no cross threading that I can see....it just doesnt want to move.
Is there anything that I can use safely on the seal or should I try a little bit of heat....I am at a loss.
Any help would be greatly appreciated.
Joelene
Nov 27, 2009 20:42 |  #2
I would take it in to a repair shop personally. That way, they break either the lens or the filter, they replace it...
sorry no tricks up my sleeve... I pay people for tricks.
www.joelenemillsphotog​raphy.ca (external link)
This is a beautiful shot ..bw!
Miniflash
Valjoy
Nov 27, 2009 21:11 |  #3
Thanks Joelene.....yes that would have been my next step.
BUT....I have just got it off...thanks to the help of my hairdryer....very low heat, just for a few seconds and it came straight off. Everything is fine.
cheers Val
RT ­ McAllister
Nov 27, 2009 22:39 |  #4
Valjoy wrote in post #9093936 (external link)
cheers Val
Glad to hear it. I was about to suggest a hammer, vasoline, and a rabbit's foot. :D
Wilt
Nov 27, 2009 22:48 |  #5
Sometimes they are 'stuck' simply because you put two of your fingers at opposite sides (9 o'clock and 3 o'clock) and that deforms the filter ring just enough to bind! Use less pressure, put three fingers around the filter (12, 4, 8 o'clock) and give a twist. It often helps to put a wide rubber band around the filter ring, so you get a better grip without excessive pressure around the periphery. And sometimes just putting turning slight pressure TOWARD the focal plane of the camera is enough to get the thing turning without distorting the filter ring via radial pressure.
Joelene
Nov 28, 2009 20:05 |  #6
RT McAllister wrote in post #9094296 (external link)
I am afraid to ask what the Vaseline and rabbit's foot are for...What state do you live in? :shock:
:lol:, sorry I found it funny! :P
Miniflash
jr_senator
Nov 30, 2009 18:58 |  #7
Valjoy wrote in post #9093323 (external link)
Any suggestions for a 'stuck filter'.....Its a HOYA filter.
In the future consider buying filters with brass rings (Heliopan or B+W), they won't seize.
Joelene
Nov 30, 2009 19:02 |  #8
my B&W seized :( but I suppose that was because I dropped my camera, it landed on my lens and turned it to an oval shape... hmm that filter ring is still on my lens...just the ring though...the glass is gone...sigh I need a new lens.
Miniflash
jr_senator
Nov 30, 2009 19:12 |  #9
Joelene wrote in post #9110784 (external link)
I don't think that is the definition of 'seize'.
2,632 views & 0 likes for this thread, 5 members have posted to it.
UV Filter stuck...
1684 guests, 175 members online
