Thread started 11 Jun 2005 (Saturday) 23:44
350D/XT dynamic range
randalcandari
Jun 11, 2005 23:44 |  #1
hi guys, just a quick question, about how many stops is your 350D's dynamic range? and what is the safe range to avoid overexposing/underezpo​sing some parts of the image? thanks!
-randal
Randal
A camera and a lens
scottbergerphoto
Joined Jun 2003
Jun 12, 2005 07:12 |  #2
I believe the dr of most of Canon's new cmos sensors is 8-10 stops.
One World, One Voice Against Terror,
Best Regards,
Scott
ScottBergerPhotography (external link)
Nightcrawler
Joined Jun 2004
Jun 12, 2005 07:19 |  #3
I thought I remember seeing a website that rated the 10D at 10-11 stops. I don't know where the XT would be though. I imagine it wouldn't be much different.
Jason - Gear - Site (external link)
etaf
Jun 12, 2005 07:23 |  #4
these may help
http://www.photo.net …a-fetch-msg?msg_id=00CMSr (external link)
http://clarkvision.com​/imagedetail/dynamicra​nge2/ (external link)
http://www.canon.com.s​g …mera&prod_type=​technology (external link)
http://www.photo.net/l​earn/drange/ (external link)
60D | EF-S 18-200 | 50mm 2.5 macro | 550EX | Pro1 | Elements
randalcandari
Jun 13, 2005 08:41 as a reply to  @ etaf's post |  #5
If the dynamic range is 8-10 steps, would that mean that if a meter reading gives the following at f5.6, 1/4, 1/8, 1/25, 1/30, and 1/80, and I set the shutter speed at 1/10sec then everything should be just be exposed properly right? or I'm misinterpreting everything. I noticed that when I do the settings above, the 1/80 areas are blown out and the 1/4 are very dark. Is this common to DSLRs or is my unit defective? by the way I'm using an XT.
Thanks!
Randal
A camera and a lens
tzalman
Fatal attraction.
Jun 13, 2005 10:16 |  #6
randalcandari -
DR which is technically (mathematically) present is a different thing from that which is perceptually present. If we assume for a moment that the digital sensor can capture a 10 stop range then we can compare it to the classic Zone System - although only approximately because Adams was talking about film and silver coated paper. The Zone System describes ten zones. from 0 (absolute black) to IX (absolute white). Zone V is the medium grey that all light metering systems strive to acheive. However, because of the nature of human vision and the limitions of our hardware (silver paper, inkjet printers, monitors) between Zones 0, I and II differences can barely be seen. Zone III is called "The Darkest Detailed Shadow." The same scrunching together is true at the top of the scale, so Zone VII is described as "Textured Highlight" and Zone VIII is so close to white that it appears blown. So instead of ten stops practical latitude we have only seven. Note that the difference between Zone V and Zone VII is two stops. Thus if the brightest highlight in which you want to retain detail spot-meters at 1/80 your exposure should be no greater than 1/20 (and not 1/10 as you wrote). At the shadow end your RAW file may contain data that will have to be edited in order to make it visible.
Elie / אלי
ron ­ chappel
Honorary Moderator
Joined Sep 2003
Jun 13, 2005 20:57 |  #7
Randalcandari
Sorry to tell you but there is nothing wrong with your camera-it's completely normal for canon DSLR's to give a 5-6 stop dynamic range in normal use.
I see this wrongly quoted SO often and it does get abit annoying (not to mention the effect it has on poor owners who think they are doing something wrong)
Anybody who is getting more than 6 stops this is doing one of the following:
Double exposure methods such as shooting RAW then making two frames (one bright,one dark) the recombining them in photoshop.This method gives a usefull one stop or more increase but does give noisier shaddows depending how far it's taken.
I've seen examples of this on the net where it's taken to rediculous extremes-claims of huge DR ..but they are counting individual bright pixels in the shaddows that are otherwise completely dark.No use in real life whatsoever
True multiple exposure methods-where several differently exposed images are combined.This gives perfect images with an unlimited DR increase...but of course can only be used for non moving subjects
Movick
Jun 14, 2005 03:40 as a reply to  @ ron chappel's post |  #8
Agreed,
Digital SLRs have approx 5-6 stops of dynamic or equivalent film contrast range (essentially the same that of color negative film. B&W film has the greatest contrast range of all current mediums at 7 stops. The aforementioned 10-11 stop DSLR range is a misnomer. The only way to achieve a full tonal range of 11 stops (pure black to pure white is to expose in 2 separate images for highlights and lowlights and combine the layers.
Movick
Pekka
El General Moderator
Gallery: 36 photos
Best ofs: 7
Joined Mar 2001
Jun 14, 2005 04:00 |  #9
Acoording to http://www.normankoren​.com/digital_tonality.​html (external link) the total dynamic range of the EOS-10D is 8.5 f-stops. Chuck Westfall mentioned that 1D Mark II has about 9 stops.
The Forum Boss, El General Moderator
AMASS 2.5 Changelog (installed here now)
randalcandari
Jun 14, 2005 08:02 |  #10
Thanks everyone for your replies. things like this makes this hobby more interesting.
So if the meter gives 1/10sec for the brightest area and I try to shoot at 1/2sec, its normal for the bright areas to be blown out?
Randal
A camera and a lens
ron ­ chappel
Honorary Moderator
Joined Sep 2003
Jun 14, 2005 16:16 |  #11
Ok,where these shutter speed numbers cross over from fractions of a sec to seconds+decimals on my camera completely confuses me early in the morning
....but i think 1/10th to 1/2 is two and a third stops
If that is right it probably shouldn't be blowing out (just).Are the metering measurements acurate-are you using spot metering?
Movick
Jun 15, 2005 03:30 as a reply to  @ ron chappel's post |  #12
<<Acoording to http://www.normankoren​.com/digital_tonality.​html (external link) the total dynamic range of the EOS-10D is 8.5 f-stops. Chuck Westfall mentioned that 1D Mark II has about 9 stops.>>
There's no way that a DSLR's tonal range can exceed that of B&W film, which as I've already mentioned is only 7 stops. Nine stops will veritably exceed the entire contrast range of pure black to pure white. Take a shot of a correctly lit pure black card or paper and a pure white sheet of same set side by side, with your MKII and see where your tonal values fall. One of the yin/yang elements will have to be compromised tonally to correctly expose the other.
I slapped together the attached 7 stop tonal ruler to exemplify this point.
Movick
randalcandari
Jun 15, 2005 07:32 as a reply to  @ ron chappel's post |  #13
yes those are fractions, i convert decimals to fractions to avoid confusions. I'm using partial metering because spot metering is not available in 350D/XT. is there a huge difference between those two metering modes?
Thanks!
Randal
A camera and a lens
Pekka
Gallery: 36 photos
Best ofs: 7
Joined Mar 2001
Jun 15, 2005 09:47 as a reply to  @ Movick's post |  #14
[COLOR=black]There's no way that a DSLR's tonal range can exceed that of B&W film
Why? Film has more noise and digital technology has improved a lot lately. Paper is out of digital equation.
Film? Paper?
Digital cameras CAPTURE a scene in bits (sensor data array). Mark II sensor captures 12 bits per channel which can store about 9 stops. The DIGIC II chip processes that data and stores that information into RAW file. After that you can use your preferred application available to convert it to e.g. 48 bit TIFF, using curves and tools to expand the data to your working gamma and color space (e.g. Gamma 2.2 ProPhoto RGB). So 8.5 stops DR in final image (.5 goes to noise) is not impossible.
So, when you say in film-tongue if you expose this target for full white the black is not black and vice versa, and that proves dynamic range of device Y is not more than X stops, in digital-tonque you capture the information in target and later use tools to EXPAND or COMPRESS the data and save it in format suitable for the TARGET media (of course in bounds of artistic requirements). The more bits you have per channel the smoother the expansion/compression result will be. RAW software can interpolate, too, and I suspect most of them do.
robertwgross
Joined Nov 2002
Jun 15, 2005 11:23 as a reply to  @ Pekka's post |  #15
From that diagram, what does 144% reflective mean? That math worries me.
---Bob Gross---
5,779 views & 0 likes for this thread, 13 members have posted to it.
1602 guests, 141 members online
