Thread started 29 Nov 2009 (Sunday) 11:15
G10 and 420 EX
carloman
Nov 29, 2009 11:15 |  #1
Any issues with this setup? Just bough a G10 and already own the 420EX flash. I have the 580EX but would rather use the 420 dues to its smaller size.
stax
Nov 29, 2009 11:27 |  #2
No issues.
http://www.flickr.com/​photos/staxnet/ (external link)
https://photography-on-the.net/forum/showthre​ad.php?t=865770
carloman
Nov 29, 2009 13:30 |  #3
Thanks.
Larop
Nov 29, 2009 16:21 |  #4
You might check this thread, there seems to be some limitations on setting flash compensation in camera and then changing modes or going into playback and then losing the in camera flash comp settings when you go back to shooting. Flash comp made on the flash is not affected.
https://photography-on-the.net/forum/showthre​ad.php?t=780137
Gerald ­ W
Nov 30, 2009 14:20 |  #5
I think that is an issue unique to the G11. No reports of similar behavior on earlier G's. I first saw this on DPReview, and several G11 users had it, but no G10's. My G7 is fine.
Jerry
Larop
Nov 30, 2009 14:58 as a reply to  @ Gerald W's post |  #6
The other thread had this comment:
xhack wrote in post #9023443 (external link)
With a G10 / 270EX combination, I can confirm you lose the menu compensation settings. Ditto with a G10 / 580EX combo.
However, the setting does remain fixed in both instances when using flash compensation within the Func/Set (centre button) option.
[This applies in AV and TV settings; I have not tried this in Green Box, P or Manual]
edit: I can also confirm the settings hold in P mode and, in Manual, the Flash Output setting survives. A brain-fade in AUTO; it was only as I switched to that setting that I realised the option did not exist. Duh!
stax
Nov 30, 2009 15:11 as a reply to  @ Larop's post |  #7
Yes, yes, but there are NO ISSUES using the 420EX with the G11/10. It is a compatible flash. Period.
The other "issues" discussed in this thread apply to all flashes (and I suspect will be addressed in a firmware update, but who knows).
1,815 views & 0 likes for this thread, 4 members have posted to it.
G10 and 420 EX
1335 guests, 159 members online
