Thread started 29 Nov 2009 (Sunday) 21:53
I broke my 24-70L, Again...yes - Again.
MrChad
Joined Aug 2004
Nov 29, 2009 21:53 |  #1
I'm beginning to think my version of this lens is cursed, that said, if they repair it this time I'm not sure much of the lens I originally purchased in 2005 will still be around. It's turning into a Lincoln's axe tail for me.
My original lens breakage was at the paws of our cat.https://photography-on-the.net …35&highlight=24​-70+mrchad
Well today I was attempting take number 2 of the cliched x-mas card photo, and my rig fell off the tripod ball head, I thought the L bracket was attached but sad to say it was not. My lens took the largest hit and is now in 2 pieces. Rig fell on carpet.
So I guess it and the 5DII will head to Canon. I'm going to have the 5DII cleaned and checked just to be safe. Some test shots with other glass appears to confirm it's working just fine.
I'm really not this big a klutz, but I am beginning to think my lens has bad karma. I know a lot of folks in here complain about a soft copy of the lens. Do they bounce any better then the hard copy I have? - sheesh. Me, this lens, and the month November are not getting along.
I kaNt sPeL...
[Gear List]
mikekelley
"Meow! Bark! Honk! Hiss! Grrr! Tweet!"
Nov 29, 2009 22:02 |  #2
Good lord, Id just sell the damn thing after you get it fixed
Los Angeles-Based Architectural, Interior, And Luxury Real Estate Photography (external link)
How To Photograph Real Estate and Architecture (external link)
My Fine Art Galleries (external link)
My articles at Fstoppers.com (external link)
deadpass
Nov 29, 2009 22:39 |  #3
ouch.
a camera
http://www.deadpass.co​m (external link)
irishman
Nov 29, 2009 22:50 |  #4
That looks . . . serious.
6D, G9, Sigma 50 1.4, Sigma 15mm Fisheye, Sigma 50 2.8 macro, Nikon 14-24G 2.8, Canon 16-35 2.8 II, Canon 24-105 f/4 IS, Canon 70-200 2.8 IS, tripod, lights, other stuff.
Marloon
Nov 29, 2009 22:58 |  #5
IMAGE: http://www.duct-tape.com/ssc061.jpg
QUICK! pick a color! (we can even make it look it you ordered a lenscoat)
I'm MARLON
Former Canon Platinum CPS member
5DII • 24L • 35L • 50L • 85L • 135L • 200LIS
Wordpress Blog (external link)Youtube Channel (external link)Twitter (external link)Gear List (external link)
Vascilli
Nov 29, 2009 23:01 |  #6
That looks like a pretty clean break to me.
Flickr (external link) | Gear List
Lowner
"I'm the original idiot"
Nov 30, 2009 05:41 |  #7
I've learnt something from this. I did not realise that the lip on the lens at that point was any more than a moulded corner. What is supposed to hold the two parts together?
Interesting to see what goes on under the skin.
Richard
MrChad
Joined Aug 2004
Nov 30, 2009 10:07 as a reply to  @ Lowner's post |  #8
The lens mount is screwed into a plastic housing under the rear metal shell. That housing snapped apart where the screws go in. All but one of the ribbon cables pulled out, the final one tore. The focus ring is stiff so that almost worries me more because that means something else is messed up internal on the lens as well. The last time my lens was repaired the focus was jumpy so the invoice said collar parts was replaced, perhaps some other or same collar parts are now dislodged again?
I believe that many of the L zooms are built in a a like fashion - engineered plastic guts. The black outer metal skin appears to protect the internals but offers no real structure to the lens. So the plastic under said skin must normally be some pretty tough stuff. Glass is heavy, I can see the engineers saving weight were ever needed this makes sense.
I mailed insured via UPS today my lens and 5DII (for cleaning) to Canon with (CPS lables) hopefully that expidites the repair and processing for both items. I've never had to use my CPS status for repair - this is sadly going to be my first go around under CPS terms. So unluckily for me I get to cash in my repair voucher discount certificate - which I had hoped to never use.
I kaNt sPeL...
[Gear List]
spider1135
Nov 30, 2009 13:43 |  #9
how much it will cost to fix for something like this?? I just wondering, can canon fix that, put two pieces together??
SMP_Homer
Gallery: 29 photos
Nov 30, 2009 13:52 |  #10
MrChad wrote in post #9107529 (external link)
I think this design is to make happen just what happened to you... drop the lens and body, and the lens will snap at a designed point, instead of damaging the mount/sensor.
I can see where in some cases, we'd want the body to take the damage, as bodies are often cheaper than some of the lenses we attach to them, but I think the idea is that if you drop a pair like that, you may still be able to unhook the broken lens parts, slap on another lens, and keep going (I've seen and heard plenty of that happen).
EOS R6’ / 1D X / 1D IV (and the wife has a T4i)
Sig35A, Sig50A, Sig85A, Sig14-24A, Sig24-105A, Sig70-200S, Sig150-600C
100-400L, 100L, 100/2, 300 2.8L, 1.4x II / 2x II
600EX-II X3, 430EX-III X3
Sean
Nov 30, 2009 14:00 |  #11
Sorry. That sucks man.
However thanks for the pics of the CARNAGE!!! Mm broken stuff!
Again sorry for your loss.
Canon 50D - 17-55mm F2.8 IS - 300mm F4L IS - 70-200mm F4L IS - 50mm F1.8 - 580EX II & 430EX - Full Gear Listing
Flickr (external link) - C&C Always welcome.
ed ­ rader
"I am not the final word"
Nov 30, 2009 14:00 |  #12
MrChad wrote in post #9105062 (external link)
i wouldn't blame it on karma :D.
were you using the regular screw type arca swiss QR? i almost lost my camear a couple of times and then i switched to the really right stuff flip lever release which to me is alot safer and much simpler to use.
i found that when i was twiddling around with the various knobs with eye to the camera i would sometimes inadvertanty loosen the screw-type QR, which really should be called a "slow release" :D.
ed rader
5D4 x2, 16-35L F4 IS, 24-70L II, 70-200L F4 IS II, 100-400L II, 14L II, sigma 15 FE, sigma 28 f1.4 art, tc 1.4 III, 430exII, gitzo 3542L + markins Q20, gitzo GT 1545T + markins Q3T, gitzo GM4562
MrChad
Joined Aug 2004
Nov 30, 2009 15:50 |  #13
ed rader wrote in post #9108964 (external link)
ed rader
Bogen RC2 style quick release system. I swear I thought I heard and felt the lever click and lock into position when I reattached my RC2 L bracket.
I kaNt sPeL...
[Gear List]
MrChad
Joined Aug 2004
Nov 30, 2009 15:52 |  #14
spider1135 wrote in post #9108846 (external link)
My assumption is they won't rejoin these two parts more then likely just replace the entire rear section of the lens if possible. I have no idea what this runs but expect to know sooner then later.
They replaced my entire front lens group (the zoom part) the last time and that ran around $200.00.
I kaNt sPeL...
[Gear List]
MrChad
Joined Aug 2004
Nov 30, 2009 15:59 |  #15
SMP_Homer wrote in post #9108909 (external link)
Perhaps but it's still broken to me all the same :P
I'm still not sold that this is a designed break point - I think broken is broken.
I'd rather not ever choose broken camera or body, ever - regardless of price.
I kaNt sPeL...
[Gear List]
6,028 views & 0 likes for this thread, 20 members have posted to it.
1374 guests, 176 members online
