Thread started 30 Nov 2009 (Monday) 13:41
Anyone know of a low-profile strip softbox for hairlight?
sdipirro
Nov 30, 2009 13:41 |  #1
I have really low ceilings in my home studio...7.5' and so I've had my hairlights off to the side, up near the ceiling and aimed at an angle. I use 24"x24" gridded softboxes usually. I do have a heavy duty lightstand and boom, but even with my subjects seated on a bench, my existing softboxes nearly touch the tops of their heads! I'm just curious if anyone knows of a low-profile (relatively flat) narrow strip style softbox that might give me a little more room to work with...and with an Elinchrom mount, of course!
Cameras: 1DX, 1D4, 20D, 10D, S90, G2
Lenses: Canon 10-22mm, 16-35mm f2.8L II, 24-70mm f2.8L, 70-200mm f2.8L IS, 300mm f2.8L IS, 200mm f2L IS, 50mm f1.4, 50mm f1.2L, 85mm f1.2L, 1.4x TC, 2x TC, 500D macro, Zeiss 21mm
Lighting: 580EX, Elinchrom 600 RX's, D-Lite 4's, ABR800, 74" Eli Octa, 100cm/70cm DOs, Photoflex Medium Octa and reflectors, PW's, Lastolite Hilite, Newton Di400CR bracket
bobbyz
Nov 30, 2009 21:19 |  #2
If setup is pretty stationary why not install the softbox in the ceiling? It can also be off in the corner or way behind the subjects not directly over head.
Fuji XT-1, 18-55mm
sdipirro
Dec 01, 2009 09:56 |  #3
It's not really stationary, and my home studio doubles as a playroom at times. Anything permanent like that really isn't an option. I can get by with how I'm doing it now, but I'd like to have the option of using a single strip box overhead on a boom if I can find one that fits the bill. All the ones I've found so far have about the same depth as the 24"x24" gridded softboxes that I use now (off on the side).
TMR ­ Design
Joined Feb 2006
Dec 01, 2009 10:28 as a reply to  @ sdipirro's post |  #4
I don't own any of the 'shallow' modifiers but when I was looking for a small softbox to use as an overhead hair light in a studio with 8 foot ceilings I finally decided to get the Photoflex 16" x 22" softbox. Keep in mind that even a shallow softbox with an Elinchrom strobe mounted will have some depth to it but at least with the 16" x 22" it's kept to a minimum. Another reason I got the Photoflex was because it accepts a grid and the grids from Photoflex are reasonably priced compared to other manufacturers.
The box works well and I've been happy with my decision and purchase.
Robert
coeng
Joined Nov 2002
May 23, 2011 10:22 |  #5
sdipirro wrote in post #9108829 (external link)
Did you ever find the solution you were looking for? If so, do you have a photo of your setup?
5D2, 600 EX-RT, STE-3, 24-70L, 70-200L f/2.8 IS II, 50 f/1.4, 85 f/1.8
dark ­ city ­ photography
Joined May 2011
May 23, 2011 10:29 as a reply to  @ coeng's post |  #6
http://shutterbug.com …quipment/0304sb​_interfit/ (external link)
I'm only suggesting this because I just saw it yesterday. Might do the trick for you.
Cheers,
Adam
3,733 views & 0 likes for this thread, 5 members have posted to it.
1698 guests, 139 members online
