Thread started 30 Nov 2009 (Monday) 21:48
Exporting/Saving files from Lightroom and Photoshop Question
cyrillo07
Nov 30, 2009 21:48 |  #1
I've been editing my pictures from lightroom and move to photoshop if i need more editing like local adjustments and using onone and nik software. My question is, what could be the best PREFERENCES to export from photoshop or lightroom so I could get the best quality of the file to PRINT to RE-EDIT. I am thinking of saving it twice so I can submit the flattened file to the lab for printing and the unflattened file so i can access my layer adjustments when i want to re-edit.
What I mean by PREFERENCES are format, color space, resolution, bit depth, etc that are usually acceptable to most labs without sacrificing the quality when i want to re-edit.
By the way, I'll be using Mpix, Bayphoto and Adoramapix as my lab.
tonylong
...winded
Gallery: 60 photos
Nov 30, 2009 23:55 |  #2
When I send a photo from LR to PS I send it as a 16 bit tiff so I have the maxim quality and latitude in the adjustments that I need to do. A PSD file would be the equivalent.
From there, you can if you wish save all layers/adjustments to that "project file", or at least as many as you can do in 16 bit. The alternatives is if your disk space is tight -- you can convert to 8 bits, flatten the layers -- those are the main things.
Then, to create a print file -- the "universal" format is a jpeg, and it should work fine with almost all printers. They will tell you about specific requirements or recommendations (as in if they prefer tiff or aRGB). But in general a high quality jpeg will give great results. Most professional companies will take high resolution images and can print them in numerous sizes, even larger than what might be considered "reasonable".
I think it's important to initially work with a printer to familiarize yourself with that to expect. If you plan on large prints, crop a portion to print at say 8x10. Check out the colors, the tones, and the sharpness in case you need need to do more work on these things.
In time, get a good workflow going with one or a few printers and things should go OK.
Tony
867 views & 0 likes for this thread, 2 members have posted to it.
1149 guests, 175 members online
