Thread started 01 Dec 2009 (Tuesday) 18:02
Umbrella Setup
Tumeg
Dec 01, 2009 18:02 |  #1
Hey forum.
I have a BIG event shoot this weekend (on the 4th), and am in need of some simple lighting advice!
I rented a really nice lighting setup from Samy's Camera, a few days ago (to give me time to get use to it all, and experiment)... Anyway, the kit came with 2 lights, 2 umbrellas, 2 stands, etc.
The umbrellas are those ones that are shoot-through, but also have a black "cover" to use as a bounce umbrella... Anyway, my question is this:
How should I setup the umbrellas? So far from my testing, it looks like 1 shoot through and 1 bounce is giving my the most favorable results... Would I just be better off\safer to use both as shoot-through? Or both bounce?
Anyway, sorry if I'm lacking the proper "slang" for this stuff... I'm fairly new to lighting (learning a lot, with this rental setup)...
| Canon 5D Mk II | Canon 17-40MM F/4L | Canon 50MM F/1.4 | Canon 85MM F/1.8 | Canon 580EX II |
EOSBoy
Dec 01, 2009 18:13 |  #2
What exactly are you shooting? And how big will the subject/people will be?
With shoot thru umbrellas, their light fall off is greater so it won't light a larger distance than reflective because light is spilled/bounced. Then again, within a certain distance, it'll also provide lots of soft light. Depending on your subjects, you can also place it closer to the subject and create softer light.
Reflective would do fine with a larger area and would be more power efficient. The downside is, depending on skin, reflective surfaces...etc. It would create more specular highlights because it's more concentrated.
If you think the set up is doing well for you, then use it! I'd use the reflective as key light and a shoot thru as fill.
http://patrickengman.c​om (external link)
Instagram: brotherly_dove
Rolleiflex 3.5F Planar
Tumeg
Dec 01, 2009 18:16 |  #3
Sorry, totally made a mental-note to say what I'm shooting, because I didn't want to look\sound like an idiot >.>
Anyway... I'll be shooting father + daughter pairs\couples, formal attire\portraits.
EOSBoy
Dec 02, 2009 14:26 |  #4
Tumeg wrote in post #9117212 (external link)
I see. I shot a formal event recently and from my experience, it'll be pretty easy. I used shoot through umbrellas exclusively but you'll do fine with either.
I even used just one strobe & umbrella in one area to light groups up to 7 people in the lobby and it did fine! Don't sweat it.
The only way I'd see it becoming a little difficult is nailing the exposure under pressure or coming late and setting up as people walk in. My Sekonic L308s light meter saved me a bunch for those situations!
1,405 views & 0 likes for this thread, 2 members have posted to it.
Umbrella Setup
1495 guests, 125 members online
