Hello everyone. I just ordered a new tripod and I am wondering if I made a good decision. This is the tripod I ordered
http://www.bhphotovideo.com …B_Tripod_Legs_Black_.html![]()
I would very much appreciate any thoughts on the subject.
Juan
JuanA Senior Member More info | Dec 01, 2009 23:24 | #1 Hello everyone. I just ordered a new tripod and I am wondering if I made a good decision. This is the tripod I ordered My kit : Canon EOS R6 and EOS R, RF 24-105mm f/4 IS L, EF‑S 16-35mm F4 L, EF 100mm f/2.8L Macro IS USM, EF 70–200mm f/2.8L IS III, EF 100-400mm f/4.5-5.6L IS II USM, Sigma 35mm Art f/1.4, Macro Ring Lite MR-14EX II, 600exII-RT, 580EX II. Gitzo GT2542 and RRS BH-55, Peak Designs Carbon Fiber Tripod, Think Tank MindShift BackLight 36L and 26L, and Think Tank Retrospective V20 2.0.
Dec 01, 2009 23:34 | #2 I would have bought the ballhead (488RC2). Jerome
lacanonamateur Senior Member 375 posts Joined Sep 2006 Location: Louisiana More info | Dec 01, 2009 23:35 | #3 With the equipment that you have it should be fine. A remote shutter release will make it even better. For the price I'd say you did well. Tripods & heads are all budget dependent to an extent. I used $20-$30 tripods for years with my old film bodies with great results. Now if your going to use heavier long lenses you will have to upgrade to something rated to support the weight of the gear your going to use with it. My Gear Listhttps://photography-on-the.net …p?p=3032213&postcount=554
JWright Planes, trains and ham radio... 18,399 posts Likes: 35 Joined Dec 2004 More info | Three handle pan-tilt heads can be a bit fussy to use because there is one handle for each movement direction. A ball head usually has one knob for all movements except panning. John
Snydremark my very own Lightrules moment More info | You should be fine; I agree that you may want to switch to something like the 488RC2 mentioned above, at some point though. - Eric S.: My Birds/Wildlife
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Dec 02, 2009 09:52 | #6 The 055 is a descendant of the 2021 (sold in USA as Bogen 2021), which a decade ago was a highly respected tripod for those who were not heavy hikers who demanded a more compact and light weight unit (the 190, decendent of the the Bogen 3001). If you want a tripod for 'at home' rather than 'air travel', the size and weight are less an issue for you. One solution previously used, to deal with the length of the collapsed 3021 (or the newer 055) is simply to remove the head from the leg set, to pack inside your luggage. Three-way heads are better for video work, ballheads are typically found to be better for still cameras. You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
| Latest registered member is semonsters 1060 guests, 109 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
