Thread started 03 Dec 2009 (Thursday) 20:00
3rd wheel
oRGie
Dec 03, 2009 20:00 |  #1
Just a thought for discussion, is it time for a 3rd control wheel for iso ?
I say this because using the 7D has me adjusting iso because I am confident in the results, so its really become an often used mix in the exposure values :)
oRGie - I am an EOS and the 7D was my idea :cool:
http://www.fluidr.com/​photos/orgie (external link)
EF70-200F4LIS - EF-S15-85IS - EF50 1.8II
xhack
Dec 03, 2009 20:22 |  #2
Dunno about the 7D, but with the 5D you can invoke ISO in the viewfinder by pressing the Drive/ISO button and adjusting with the back wheel. This does not seem to work in the 20D.
~ Wallace
Replaces
Dec 03, 2009 20:29 |  #3
mmmm dedicated ISO dial
doesn't seem like its going to happen anytime soon until Hi-ISOs get much more better.
FlyingPhotog
Cream of the "Prop"
Dec 03, 2009 20:29 |  #4
On the MkIII, the SET button can be programmed to allow you to push it and turn the rear wheel to change ISO.
No such feature on the 7D?
Jay
oRGie
Dec 03, 2009 20:48 as a reply to  @ FlyingPhotog's post |  #5
Havent looked at the set button options for that, but I just use the iso button and top wheel, viewed through viewfinder yes, so no problem really, just that its something I find myself doing a lot more often now.
PacAce
Joined Feb 2003
Dec 03, 2009 21:10 |  #6
FlyingPhotog wrote in post #9131036 (external link)
What advantage does pressing the SET button have over pressing the ISO button at the top of the camera for setting the ISO? Since you have to press a button either way, you're not really saving anything finger strokes as far as I can see. :|
@ oRGie: Personally, I can't see another dial being added just for setting the ISO when you can do the same thing by pressing a button and then turning a dial.
...Leo
Gary ­ McDuffie
Dec 03, 2009 21:15 |  #7
PacAce wrote in post #9131256 (external link)
The SET button is much easier to reach for some of us with short fat fingers. I'll rephrase. Actually, it is much easier to find. :lol:
Gary
"I'm not much of an artist, but I like to document certain things that I see."
5DII, 7D, some L, Manfroto one and three legged devices, shooting & learning bit by bit via POTN
bacchanal
Dec 03, 2009 21:30 as a reply to  @ Gary McDuffie's post |  #8
Uh...I don't know if the 7D uses the same configuration as the 5DII, but on the 5DII the ISO button is about an inch away from the shutter button. It really doesn't take a ton of effort to hit the button and turn the wheel.
PacAce
Joined Feb 2003
Dec 03, 2009 21:35 |  #9
bacchanal wrote in post #9131374 (external link)
^ +1 although, on the 7D, they moved the "light" button from the extreme left position to a spot to the right of the ISO button so people used to the "old" arrangement of the buttons at the top need to get used to not pressing the "light" button when they really want to press the ISO button. But that's the same with the 5DII, too, though.
...Leo
FlyingPhotog
Cream of the "Prop"
Dec 03, 2009 21:47 |  #10
I actually had it suggested by a sports shooter.
I don't have to take my finger off the shutter button and can change ISO on the fly if a subject moves from sun to shadow or vice versa.
Jay
bacchanal
Dec 03, 2009 21:53 |  #11
FlyingPhotog wrote in post #9131459 (external link)
That brings up another thing...on the 5DII (and I presume the 7D) the ISO is controlled by the main wheel, so you have to take your finger off the shutter button either way. I'm not sure if this is switchable via a custom function or whatever, but I don't believe it is on the 5DII.
Gary ­ McDuffie
Dec 03, 2009 22:01 |  #12
bacchanal wrote in post #9131507 (external link)
To be honest, I don't remember for sure if just the wheel, or both will control ISO on the 7D. Many of the functions can be done by either when active.
Gary
PacAce
Joined Feb 2003
Dec 03, 2009 22:19 |  #13
The 7D and the 5DII doesn't allow you to reassign the ISO function so the discussion is moot as far as the 7D is concerned. But on the 1DIII, the ISO button, whether using the default button at the top of the camera or reassigned to the SET button, is single-purposed, i.e. not assigned for any other purpose, so you can use either the main dial or the quick dial to change the ISO. So I can see where using the SET button for changing ISO can be beneficial if one doesn't want to let off on shutter button. But then, that begs another question. In what situations would you always want to keep the index finger on the shutter button even when changing the ISO? It's not like it's hard to find and get back to once you move your finger off of it. :)
...Leo
FlyingPhotog
Cream of the "Prop"
Dec 03, 2009 22:28 |  #14
PacAce wrote in post #9131679 (external link)
The 7D and the 5DII doesn't allow you to reassign the ISO function so the discussion is moot as far as the 7D is concerned. But on the 1DIII, the ISO button, whether using the default button at the top of the camera or reassigned to the SET button, is single-purposed, i.e. not assigned for any other purpose, so you can use either the main dial or the quick dial to change the ISO. So I can see where using the SET button for changing ISO can be beneficial if one doesn't let off on shutter button. But then, that begs another question. In what situations would you always want to keep the index finger on the shutter button even when changing the ISO? It's not like it's hard to find and get back to once you move your finger off of it. :)
Following a football player from sun to shade, I can swing the ISO from 100 to 400 without coming off the shutter.
I'm already shooting wide open for isolation so I have no more aperture and I can't slow the shutter speed or else I'll get motion blur so bumping the ISO is the answer. K? :rolleyes:
Jay
PacAce
Joined Feb 2003
Dec 04, 2009 07:00 |  #15
FlyingPhotog wrote in post #9131738 (external link)
OK. Whatever floats your fancy. (<== That's for using the rolling eyes on me since I did ask a legitimate question. ;) :mrgreen:)
...Leo
2,189 views & 0 likes for this thread, 10 members have posted to it.
3rd wheel
647 guests, 124 members online
