Thread started 05 Dec 2009 (Saturday) 03:41
I love photography.
thebikefiend
Dec 05, 2009 03:41 |  #1
Photography is great. It's one of those "hobbies" that I'm actually willing to stick with, through thick and thin. Since I got into photography, I've taken a fair number of good shots, a good amount of decent shots and about eight thousand lousy shots.
Normally I analyze my photos based on information from this site and google. However, in this case I was particularly disappointed with my evening shoot. I managed to get some very interesting shots. However, they were rubbish from a technical stand point. I try not to use flash in low light.
The following photo's bokeh is particularly soft(!), and the reds are overexposed. Not to mention the high level of noise. I cropped the image to reveal the absolute worse point. The exposure on the subject was fine. The photo was taken with a T1i, 50mm 1.8 prime. 400 ISO, 1/10, Ap priority, at 1.8 (autofocused). Without seeing the full picture, what do you all think? Any suggestions? The second cropped photo is a slightly noisy, but preferred bokeh.
SwitchBlade
Dec 05, 2009 03:59 |  #2
At 1/10 without IS on the lens you are bound to get motion blur hand held, that motion blur will effect the bokeh. Minimum of 1/60th or 1/focal length which ever is shorter was the rule of thumb I was given. That said I can only see what I presume to be the edges of the subject.
TBH an idea of what you were trying to achieve would help. Any reason why you choose not to use the flash?
5D | 40D | Σ24 f1.8 | 50 f1.8 II | 85 f1.8 | 70-200 F4L | 540EZ x2 | Nissin Di622
thebikefiend
Dec 05, 2009 04:10 as a reply to  @ SwitchBlade's post |  #3
I suppose my goal is to get great, low-light portrait shots. I don't like to alert my subjects with a flash for focus and a flash for the exposure. I guess I'm trying to achieve the impossible. I want low-noise, sharp, in-focus images without flash in low light. (Hehe.) Perhaps it's only possible with a higher end DSLR. Or, perhaps I should learn to utilize a decent flash? Not sure.
SwitchBlade
Dec 05, 2009 04:40 |  #4
With IS you can get a claimed 4 stop equivalent on shutter time with some lenses. So that could help here. I'm guessing you are using the on board flash rather than a flashgun. Flashguns emit an infra red light to focus with which means no warning before the flash fires. Though if you have enough light to focus with without the flash IIRC you can turn of the focusing flashes as well as preflash in the custom functions menu, so the onboard should only flash when you take the picture.
May be wrong on the focusing flashes. Could always focus then press the flash button to pop the flash up before taking the shot if so.
yogestee
Dec 05, 2009 05:01 as a reply to  @ SwitchBlade's post |  #5
Bokeh is always soft as opposed to the main subject because bokeh is the quality of the out of focus areas.. Sharp bokeh is an oxymoron!! It just doesn't exist..
Jurgen
yogestee
Dec 05, 2009 05:04 |  #6
Definitely not!!
Low noise, sharp in focus images in low light are possible with any DSLR.. Hone your shooting techniques..
Jurgen
PhotosGuy
Cream of the Crop, R.I.P.
Joined Feb 2004
Dec 05, 2009 10:19 |  #7
Generally, you're always going to see noise in the dark areas, because they're "underexposed" by definition. The key to mostly noise free shots is to use a high enough ISO to properly expose the important areas of the image.
Another way to reduce high ISO noise is to slightly overexpose in RAW & then dial it back in processing. And you have to be careful to get just the exposure you need.
Gavin shoots a lot at various high ISOs & provides fun captions as well.
The week's sporting events in images...
Some from Christan at ISO 800 using a 40D: New Pee Wee (11-12 yr old) Baseball
ISO 1600 @ 20D. EXIF is included in:
The Johnny Headband Band
ISO 3200 & 20D is pushing the 20D limits. EXIF is included in:
Barbara Payton & Her Band @ ISO 3200
Need an exposure crutch?
Why?
Post #47
thebikefiend
Dec 05, 2009 21:23 as a reply to  @ PhotosGuy's post |  #8
Thanks for the tips. It's good to see photos that have similar characteristics to mine. Sounds like it's back to the fundamentals for me.
913 views & 0 likes for this thread, 4 members have posted to it.
I love photography.
2886 guests, 137 members online
