Thread started 05 Dec 2009 (Saturday) 10:57
Repairing a Manfrotto 222 head
Redr8
Dec 05, 2009 10:57 |  #1
Folks, hope someone can help. I recently picked up a Manforotto 222 head on the cheap - it was almost a steal to be honest - as the previous owner had "wrecked it" by lubricating the ball with WD40 or similar. Consequently, it wouldn't hold anything more than a compact without tipping over. None the less, I bought it and have been soaking up as much of the lube as I can and it is now useable in upright mode, but if I lean it over, it still wont hold the weight of my camera.
So.....would anybody have a service manual on one of these as I would like to take it apart and fix it up. I'd rather have a diagram before stripping it so I know where to put all the bits back when it springs apart !!! I asked a Manfrotto dealer about the cost of repair, ad it came as no suprise it was about the cost of a whole new head.
Any advice appreciated.
Regards,
RedR8
400D + 28-105 L + Sigma 18-125 + 70-300 IS + 50 f1.8 + 550EX + 420EX
No idea, no clue, and the odd good photo.... :D
Lowner
"I'm the original idiot"
Dec 05, 2009 12:50 |  #2
Manfrotto do "exploded" diagrams on their website for everything they make. I used the 486 diagram to dismantle it and do the repairs I needed.
While the Manfrotto site is not easy to navigate (thats the understatement of the year!), its worth the struggle.
Richard
PixelMagic
Dec 05, 2009 13:25 |  #3
Redr8 wrote in post #9140045 (external link)
I've never used the 222 but I've owned two 3265 heads which are the predecessors to the 222.
I doubt the head you have needs any repairs more than absorbing the lubricant. Most people don't know it, but all you need is a 5/16" hex key or "Allen wrench" to adjust the tension of the head. Once its tightened you'll be able to support almost any DSLR camera.
Its not very obvious where you need to insert the wrench but if you examine the head carefully you'll see the socket (it looks like a recessed screw hole) near where the top connects to the ballhead.
JWright
Joined Dec 2004
Dec 05, 2009 22:44 as a reply to  @ PixelMagic's post |  #4
http://www.manfrotto.c​om …rd/pdf/2/222_20​020408.pdf (external link)
http://www.manfrotto.c​om …rd/pdf/2/222_20​050510.pdf (external link)
John
SkipD
Joined Dec 2002
Dec 06, 2009 09:02 |  #5
I have never seen perfectly good 222 head that was capable of holding any significant weight (such as a 20D with a 24-70 f/2.8L lens)off to the side without drifting. There's just too much leverage because of the distance between the camera mount and the ball. I've tested a few - both new ones in stores and one owned by a friend of mine - and been very disappointed in their performance.
Quite honestly, if you want a decent ball head for general purpose use on a tripod and at a reasonable price, the Manfrotto 488RC2 is hard to beat.
Skip Douglas
Redr8
Dec 07, 2009 05:19 as a reply to  @ SkipD's post |  #6
Thanks all for their help, particulalry John with his PDF links...it was exactly what I was after. To say the manfortto site is user friendly is far beyond a laughing matter, and despite my searches, couldn't find what I needed. Thanks
IMAGE: http://www.hamaraforums.com/style_emoticons/default/bow.gif
Regards,
RedR8
JWright
Joined Dec 2004
Dec 07, 2009 16:14 |  #7
Redr8 wrote in post #9149524 (external link)
[GIFS ARE NOT RENDERED IN QUOTES]
Glad to be of service...
Their site is better than it used to be. I had occasion to need to repair broken levers on two different tripods and I ended up e-mailing them to get the diagrams and parts I needed. Now it's a bit easier to find the pdf diagrams for their gear...
John
fishinfool
Dec 07, 2009 18:23 |  #8
Thanks JWright! The pdf links will help me if and when I have any problems with my 222.
6D + BG-E13, 7D2 + BG-E16, 7D + BG-E7, 16-35 f/2.8L II USM, 100-400mm f/4.5-5.6L IS II USM, + 1.4x III, 70-200 f/2.8L IS USM, 24-105 f/4L IS USM, 100 f/2.8L IS USM Macro, 50 f/1.4 USM, 15-85 f/3.5-5.6 IS USM, 580EX II & 430EX II, Manfrotto MT057C4 + RRS BH-55, Manfrotto 055CXPRO3 + Acratech GP, Manfrotto 190CXPRO3 + 128RC , Manfrotto 681B + Sirui L-10, Gorillapod Focus + Manfrotto 234RC.
Redr8
Dec 07, 2009 19:29 as a reply to  @ fishinfool's post |  #9
Strip, clean, reassemble and tighten the 'tension screw'. Has worked a treat. Will now hold he 400d + lens + flash on the side witout movement !!!
Not bad for Aus$15 :)
Regards,
RedR8
fishinfool
Dec 07, 2009 19:33 |  #10
Not bad at all Red. I payed well over a hundred bucks for mine. Good for you.
shadowlands
Mar 21, 2010 13:30 |  #11
PixelMagic wrote in post #9140623 (external link)
You rock!!! I adjusted the tension on mine and it now holds my camera, even when vertical. Thanks so much!!!
Nikon D300
Nikon D90
Nikon DX AFS 18-300 VR
Nikon DX AFS 50mm F1.4G
Nikon SB-600
AntonLargiader
Mar 14, 2011 20:19 |  #12
New URLs for the parts PDFs:
http://mediacdn.shopat​ron.com …2_20050510.pdf?​1272346403 (external link)
http://mediacdn.shopat​ron.com …2_20020408.pdf?​1272346403 (external link)
T2i . 18-55 IS . 70-300 IS USM . 70-200 2.8L IS . 28mm 1.8 . 100 Macro . 430EX II . TT1/TT5 . Bogen/Manfrotto 3021 w/3265 ball-mount
msowsun
Gallery: 14 photos
Mar 15, 2011 01:33 |  #13
Manfrotto 222 disassembly and ball cleaning instructions: http://bogentripodpart​s.com/JOYSTICKHEAD%20A​SSEMBLY.htm (external link)
IMAGE: http://i2.photobucket.com/albums/y17/msowsun/photo%20stuff/Photo5/_1-17.jpg
Mike Sowsun / S110 / SL1 / 80D / EF-S 24mm STM / EF-S 10-18mm STM / EF-S 18-55mm STM / EF-S 15-85mm USM / EF-S 18-135mm USM / EF-S 55-250mm STM / 5D3 / Samyang 14mm 2.8 / EF 40mm 2.8 STM / EF 50mm 1.8 STM / EF 100mm 2.0 USM / EF 100mm 2.8 USM Macro / EF 24-105mm IS / EF 70-200mm 2.8L IS Mk II / EF 1.4x II
rvdw98
Mar 15, 2011 02:39 |  #14
You did notice that the OP already fixed his 222 in December of 2009? :D
Roy
AntonLargiader
Mar 15, 2011 05:43 |  #15
Plenty of other people have 222s. I found this thread looking for a way to replace the loose latch on mine, and noticed the bad URLs.
14,087 views & 0 likes for this thread
Latest registered member is sankulmama
1060 guests, 279 members online
