Did a portrait of three kids today. I have a base photo with two of them looking good, but the third is a mess So I need to grab a head from another shot and replace.
Whats the best way to do that is cs4?
Thanks!
mattograph "God bless the new meds" 7,693 posts Joined Jan 2008 Location: Louisville, KY More info | Dec 06, 2009 21:56 | #1 Did a portrait of three kids today. I have a base photo with two of them looking good, but the third is a mess So I need to grab a head from another shot and replace. This space for rent.
poloman Cream of the Crop 5,442 posts Likes: 7 Joined Dec 2006 Location: Southern Illinois More info | Dec 06, 2009 23:10 | #2 Open both images at the same time. Select the head in the image that you want to use. I like to select with the quick selection tool and refine with the quick mask tool. Select the pointer tool and click on the selected head. Drag it onto the image where you want to use it. Use edit transform to scale and rotate it as needed. It will be on it's own layer. You may want to use Layer/Matting/Defringe. You may also have to adjust the swapped head for color. "All those who believe in psychokinesis, raise my right hand!" Steven Wright
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | Dec 07, 2009 03:57 | #3 Lasoo the good head, feather 5-20 pixels, copy to other image, convert to smart layer, transform. Use adjustment layers if you need to match color of brightness, just alt click between the new head layer and the adjustment layer to make the adjustment only apply to the head layer. Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
Patrick Senior Member 596 posts Joined Jun 2008 Location: WV More info | I did a group shoot where in one image some people were smiling and some were not and in another others were smiling. I took a few shots and between them I had a smiling face on every person. While shooting, neither they nor I moved. The only thing that changed was the facial expressions. Bodies, Lenses, Lights, Stands, Transmitters, Receivers, Tripods, Meters, etc...
mattograph THREAD STARTER "God bless the new meds" 7,693 posts Joined Jan 2008 Location: Louisville, KY More info | Dec 07, 2009 20:48 | #5 Thanks for the input. Will be working on it in the next few days. I might post the results. This space for rent.
StealthyNinja Cream of the Crop 14,387 posts Likes: 4 Joined Nov 2007 Location: Mythical Tasmania (the one with lots of tall buildings in the semi-tropics, A.K.A. Hong Kong) More info | Dec 08, 2009 04:04 | #6 Permanent banJust cut the head out roughly. Then use layer mask taking away the stuff you don't want with a black brush. Then if you make a mistake you can swap to a white brush to bring the image back. Better than being stuck with what you've got by using quick select/quick mask combo.
poloman Cream of the Crop 5,442 posts Likes: 7 Joined Dec 2006 Location: Southern Illinois More info | Dec 08, 2009 22:12 | #7 Stealthy Ninja wrote in post #9156141 Just cut the head out roughly. Then use layer mask taking away the stuff you don't want with a black brush. Then if you make a mistake you can swap to a white brush to bring the image back. Better than being stuck with what you've got by using quick select/quick mask combo. ![]() BTW I've swapped heads etc. heaps of times. People don't notice if you don't tell them (assuming you get the lighting right). This sounds good. "All those who believe in psychokinesis, raise my right hand!" Steven Wright
StealthyNinja Cream of the Crop 14,387 posts Likes: 4 Joined Nov 2007 Location: Mythical Tasmania (the one with lots of tall buildings in the semi-tropics, A.K.A. Hong Kong) More info | Dec 08, 2009 22:20 | #8 Permanent banHard works is for suckers and the would be rich.
RenéDamkot Cream of the Crop 39,856 posts Likes: 8 Joined Feb 2005 Location: enschede, netherlands More info | Dec 09, 2009 05:03 | #9 "I think the idea of art kills creativity" - Douglas Adams
mattograph THREAD STARTER "God bless the new meds" 7,693 posts Joined Jan 2008 Location: Louisville, KY More info | Dec 09, 2009 11:48 | #10 Awesome. Thanks! This space for rent.
Dooms_day Senior Member 509 posts Joined Jan 2009 Location: Maryland, USA More info | Dec 09, 2009 12:09 | #11 Yeah when making those action shots where a bunch are merged into one, i put one photo on a new layer at a time, and erase everything around the subject, and the background sticks from the first image, as well as the subject in the first image, hopefully at a diferent place. but in your scenario, i would open both pics, and clone stamp the face starting at say, the pupil of one eye, and clone until you get to the edges Canon EOS-1D mk ii + 70-200 4.0 USM L + Sigma 28-70mm 2.8-4 + Nifty 50
| Latest registered member is semonsters 1592 guests, 137 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
