Thread started 08 Dec 2009 (Tuesday) 00:50
Which lens to choose?
aznlilrs
Dec 08, 2009 00:50 |  #1
So I've been looking around at a couple of lens to use as a better walk-around lens than my 28-135mm. I would like a faster aperture and possibly sharper also. Not really looking to sell my 28-135mm as I need the longer end occasionally, but what would be some good options that are under $400-500?
I looked at the 17-40L, 35mm, and the Tamron 17-55mm
Canon 40D | 17-50mm | 50mm f/1.8
kimchibrown
Dec 08, 2009 01:18 |  #2
I have no experience but a lot of people like the Tamron 17-50
Edit: But if I was you, if I got the Tamron 17-50, I would sell the 28-135 and spend a little more and get the Canon 70-200 F/4 non IS.
ckckevin
Dec 08, 2009 02:07 as a reply to  @ kimchibrown's post |  #3
I think you still wants the 28-135 for the IS on the long end, right?
For a lens that can do wide angle, i would second kimchibrown for a 17-50mm. But it also depends on whether IS is needed or not (generally you don't need it for this focal length, but who knows).
sigma 18-50 also got pretty good review too
tokina 16-50mm
Kevin life= learning
500D, Canon 10-22mm, Tamron 17-50mm 2.8, Canon 60 macro, Canon 85mm 1.8, Sigma 8mm 3.5, Sigma 30mm 1.4, Sigma 50-150mm 2.8, Kenko SP300 1.4x, efs extension tubes, 580EX, and lens that i don't like
aznlilrs
Dec 08, 2009 19:27 |  #4
So I've narrowed it down to either the Tamron 17-50mm f/2.8 and the Sigma 30mm f/1.4. Which is a better walk-around lens to use and has better reliability?
NoFitState
Dec 08, 2009 19:46 |  #5
The tamron will be a more flexible option as a 'walk-around' lens, and really is good optically (I would have gone for a tamron if the VC option had been available at the time). But to my mind, the important questions to ask yourself in this situation are:
- Do you find 28mm wide enough?
- Have you used primes with fast apertures before?
If you need wider than your current lens, then go with the Tamron. But you may want to try out a really fast prime first to see if you like the possiblities a super thin DoF opens up to you. As much as I love my 17-55 for its sharpness/flexibility there are a lot of times the I need to shoot below 2.8 for light & dof reasons
5D3 || Canon 135L || Sigma 35 1.4 || Sigma 50mm 1.4 || 600ex-rt || Benro C2682TB1 Tripod || Lowepro Flipside 300 || Crumpler 5 Million Dollar Home
ckckevin
Dec 08, 2009 20:43 |  #6
NoFitState wrote in post #9160990 (external link)
I agree. I think you should be more specific to the meaning of "walk-around". If you need the wide angle for landscape or indoor gathering events, Tamron 17-50 is definitely a good choice. But if you think that you don't really need anything wider, then 30mm 1.4 will open up a lot of opportunity in low light.
889 views & 0 likes for this thread
Latest registered member is Agedphotographer
675 guests, 314 members online
