TaDa wrote in post #9160364
I've been considering either a 17mm TS-E or 24mm TS-E. I did a search of the forum, but couldn't find someone discussing this. Is there any specific reason that they're only made in manual focus? Since you can manually focus the lens from MFD to infinity, I would assume that it has nothing to do with the lens elements, so I'm just curious as to why.
It is exactly because because of tilt and shift, that these lenses don't have AF.
Let's say you tilt the focus plane horizontal. Where would you let the lens focus now? Anywhere in the focus plane, focus is achieved. How can you let the camera know where to focus, even if redesigning the EOS mount completely, just for tilt shift lenses? BTW, this is also true for contrast focusing. How would you go about it and how would you tell the camera and/or lens?
Furthermore, as you know, the AF points all are within about 1/3 of the image in the centre, certainly on FF. This is because the AF sensors can't handle light falling in from very obtuse angles. When tilting and/or shifting a lens, these angles get much greater, to make AF even more impossible.
Also, with the movements possible, it gets rather hard to put in an AF engine, and keep the movement of the focus ring large and accurate enough to do proper, precise and acurate manual focusing, something you would always want to have with such a lens. A small difference in focusing may mean a world of difference, especially when using any of the movements.
Then there is the question where to put the focusing engine, and the ancillary stuff it needs? With the movements possible, it would likely mean making the lens a lot wider than it already is.
The most important reason, however, are the first two mentioned. There is no rhyme or reason on how and where to focus when using tilt, and it would be hard, no impossible, for shift because of AF system limitations.
Kind regards, Wim
