Thread started 09 Dec 2009 (Wednesday) 13:02
Perspective in Photography - Part I
sudipta_shaw
Joined Sep 2009
Dec 09, 2009 13:02 |  #1
Dear Readers,
In this article I will try to explain how perspective works in a 2D photograph with some tips, myths and example photos.
When we see a photograph on computer screen or on prints, we are looking at a 2-dimensional representation of a real 3-dimensional scene. And that is what photography is all about - capturing a 3D scene onto a 2D image. I used to wonder how do photographers demonstrate "depth" or sense of "scale" in a (good) photograph. They use the concept of
Perspective.
Example photo:
Click to Enlarge (external link)
This is one of the tricky areas of photography which if a photographer is not consciously aware of, can produce unwanted "distortions" or "flat" uninteresting images.
3D is real. A 2D depiction of a 3D scene is just an illusion exploiting how our brain synthesizes information to determine the "depth" in real-time. Powerful compositions can be created by applying the concepts of perspective in effectively converting a 3D scene into a 2D translation. For simplicity of understanding the complete in-depth discussion on perspective, I have divided the concept into two parts.
In this first part, I would discuss on the common methods used by photographers to achieve the sense of depth. And then in Part II of this discussion, I will cover (rather un-cover) the general myth about focal length and perspective control/corrections as well as interesting ways of "manipulating" perspectives.
Let's start by formally defining "Perspective":
Perspective in photography can be defined as the sense of depth or spatial relationships between objects in the photo, along with their dimensions with respect to the viewpoint (camera lens or the viewer).
Now let's come down to the techniques -
I. Blocking, overlap or obstruction
This is probably the dumbest thing to tell. But let me tell you anyways. When we see an object blocking the view of another object, the first object is nearer to the viewer than the latter.
This clue to our brain regarding distance can be utilized in a photograph to depict the "depth" or distance between the objects also called overlap perspective. If this overlap is repeated in a same picture the viewer gets a sense of depth among various objects lying in a 3D reality through the perception of the relative distance of objects made by partial blocking and hiding.
Example Photo:
II. Relative Size
Our brain is very complex but gets fooled easily. We have a notion that when an object becomes more distant, it appears smaller than the one which is closer to the viewer.
In reality our brain has encodings of "natural" size of different objects like trees, cars, people and animals. So when we see a person twice as big as building, we cannot rationally conclude that the person is actually twice as big in reality. Our brain tells us that the building is farther away for a person. Alternatively when we carefully place different objects at different distances but giving an illusion that they are in the same plane produces funny images which I will discuss in detail in Part II "Playing with Perspective" section.
So in a nutshell, our brain makes an evaluation of the sizes based on "known" objects in relationship with other objects in the photo. Thus a distance is "imagined" in the brain and creates the "depth" in the photo that the photographer is looking for. This is also called "scaling" which helps the viewer to determine the actual size or relative size of the objects in the picture.
Here's an example photo:
III. Linear, Rectilinear and Vanishing Point
As already mentioned earlier that a 2D image is nothing but an illusion of a 3D scene, but nevertheless artists and photographers utilize this illusion effect as an important compositional factor in their works.
The human eye judges distance by the way lines and planes converge at an angle. This is known as linear perspective.
Example photo:
This when expanded to the rectangular objects, you find that some of the lens (fish-eye and panoramic) produces objects at the sides much smaller than it actually is and the objects at the center much larger that it's actual size. Geometrically all straight horizontal lines at the lens axis level are represented as straight lines, and all other straight vhorizontal lines either above or below the lens axis level are reproduced as curved lines. But with "rectilinear perspective" the straight lines in the subject are reproduced straight in the picture (normal lenses are rectilinear lenses) which is way we see things normally.
Example photo:
(note that in this photo there is slight distortion at the base and the vertical lines of the building. This is a classic case of perspective projection distortion)
It is noteworthy to mention that any photo is subject to "perspective projection distortion" which can be controlled and corrected with various methods that I will describe in Part II of this series.
The fish-eye and panoramic lenses produces "false" perspectives and are used only to produce "special" effects on purpose (more on this in Part II: Playing with perspective).
So back to linear perspective. Lines that are parallel to each other when seen at a great distance gives us the sensation of meeting (at vanishing points) for example in rail tracks. This "converging parallel lines" illusion can be used to show "distance" or depth in the photo.
See example photo:
IV. Lack of Sharpness, Color Quality or Contrast
We are accustomed to our eyes not able to figure out objects in the distant far off (due to lowering of contrast or scattering of light or both). We can use this information to "create" the effect of lack of sharpness/contrast by controlling the depth of field. Now controlling depth of field is totally different subject area in Photography and I do not want to mix it with the current discussion of perspective control. But just for the sake of completeness, I can give you a quick hint: just focus your lens slightly shorter than infinity so that the farthest object looks blurred thus giving the viewers a sense of distance.
Also atmospheric conditions like haze/fog/dust can cause loss of image sharpness at a distant. Since the effect of this "haze" (scattering of light due to particles in the air) is proportional to the distance of the objects from the lens, we can use this information as well in composing the shot.
See example photo:
Of course, there are various different factors that contribute to varying atmospheric conditions but the result effect of reduction of contrast, brightness and saturation can make our eyes believe that we are looking at something really distant compared to the objects that are clear, sharp and vibrant color.
So next time when you are trying to compose a photo, before pressing the shutter, think again. Are you able to succesfully illustrate the "3D-factor" through any (or all) of the above mentioned "illusion" methods. In Part II of this article, I will explain the myth on perspective, zooming/framing and distortion corrections.
Talk to you soon,
-Sudipta
Homepage: http://www.sudiptashaw​.com (external link)
Photography: http://www.sudiptashaw​.com/photography/ (external link)
Facebook: http://www.facebook.co​m/shawphotography (external link)
Twitter: http://twitter.com/sud​ipta_shaw (external link)
SkipD
Joined Dec 2002
Dec 09, 2009 20:02 |  #2
I suspect that your Part II will dovetail nicely with the "sticky" (now in the General Photography Talk forum) tutorial that a few of us wrote, titled Perspective Control in Images - Focal Length or Distance?.
I'd like to invite you to copy your articles into the "sticky" thread.
Skip Douglas
sudipta_shaw
Joined Sep 2009
Dec 10, 2009 09:08 |  #3
SkipD wrote in post #9167726 (external link)
Thanks a lot, Skip D.
Wow. Actually going through the above thread, my Part II looks actually redundant. :D
I have similar illustrations and explanations of Focal Length / Perspective myth. So I think I would rather filter my article and keep only the sections on "Playing with Perspective" and "Correcting Perspective Distortion".
I have actually posted the whole of Part II in my website for now:
http://www.pleasurepho​tography.com …ve-in-photography-part-ii (external link)
But I would move this post to the sticky.
Thank you.
-Sudipta
chauncey
Dec 10, 2009 10:34 as a reply to  @ sudipta_shaw's post |  #4
Hence wide lens does not exaggerates or distorts perspective, and telephoto lens does not compresses it
I discovered this to be true when I took several telephoto photomerged images and cropped them to the same WA image...guess what...ya couldn't discern which was which. ;)
directorj
Dec 10, 2009 10:48 |  #5
scrolled through it really fast..looks like a good read. I'll read it after class!
I realized that the photographer is never in the pictures :cry:
Wilt
Dec 10, 2009 15:20 |  #6
Great opening post, to remind people what elements constitute our perception of 'perspective' in a scene or in a 2D depiction of it. It is a good lead and a fundamental to understanding why FL itself is not the alteration of perspective, but that camera position is what really drives perspective differences.
sudipta_shaw
Joined Sep 2009
Dec 12, 2009 09:29 |  #7
I apologize for my ignorance of "forum tools"... Is there a way to "move" this post to the sticky? Or I have to "copy" the content into the "sticky" topic.
Thanks.
-Sudipta
Wilt
Dec 12, 2009 11:07 |  #8
One merely needs to ask a moderator to make changes desired, but I think Skip's link is a good start, as the other thread continues to accumulate random discussion posts and is fairly lengthly, and I wouldn't want your post to get lost in that meandering thread!
SkipD
Joined Dec 2002
Dec 12, 2009 13:57 |  #9
sudipta_shaw wrote in post #9182844 (external link)
The easiest way for you to do the task is copy your first post here and then paste it into a "reply" to the 'sticky' thread. A moderator could also do that for you, but you may want to do it yourself so you can follow it up immediately with part 2. That way there would not be other posts in between your two article sections in the 'sticky' thread.
I would not suggest having the moderators move everything in this thread or even deleting this thread. It has plenty of merit on its own.
Skip Douglas
1,232 views & 0 likes for this thread, 5 members have posted to it.
2795 guests, 140 members online
