For the naysayers and the ones that still can't decide on leaving the xxD series for 7D I want to give you an idea how 7D performs with moving subjects.
I want to state that this was not intended to be a test from the begining but after seeing how well camera kept focus on the flying eagle, even though it flew behind the tree, I figured I will share the results.
I was taking the burst of shots and when I saw the eagle behind the tree I stopped shooting. Now I regret that I didn't continue taking more pictures to see when the camera will eventually fail to focus.
Following shots are a downsized full frames (not cropped, only resized for the web). Please note that eagle isn't on the center of the frame (my fault) but camera kept focus anyway - this is where the extra focusing points of 7D come handy
Shots were taken with 400mm f/5.6 lens, using the AI Servo mode, 8fps, center AF Point Expansion with following C. Fn. III settings:
1 - one stop before SLOW setting
2 - 0
3 - 0
4 - 1
| HTTP response: 404 | MIME changed to 'text/html' | Byte size: ZERO |
| HTTP response: NOT FOUND | MIME changed to 'image/png' | Redirected to error image by ZENFOLIO PROTECTED |
EXIF data: 1/1250s at f/7.1 ISO 400
For a little bit bigger pictures on the black background click here =>
AF tracking
