I am looking to get remote transceivers for my flashes to shoot externally from my camera.
What are my best options? Pocketwizards? Any other good options?
RyanM Senior Member 751 posts Joined Apr 2007 Location: Philadelphia, PA More info | Dec 10, 2009 22:05 | #1 I am looking to get remote transceivers for my flashes to shoot externally from my camera. Canon 5DMKII w/grip // Canon 40D w/grip // 70-200mm f/2.8L IS // 16-35mm f/2.8L II // 50mm f/1.4 // 85mm f/1.8 // 430 EX ll
Dec 10, 2009 22:07 | #2 Cybersync from Alienbee/Paul C Buff, Elinchrom Skyports, Radio Popper, Yongnuo RF602 Jerome
Dec 11, 2009 02:19 | #3 RyanM wrote in post #9174670 I am looking to get remote transceivers for my flashes to shoot externally from my camera. What are my best options? Pocketwizards? Any other good options?
Nikon D810 Nikon 50F/1.4G - Nikon 70-200F/2.8II
agphotography Goldmember 3,726 posts Likes: 5 Joined Mar 2008 Location: Orange County, CA More info | Dec 11, 2009 02:24 | #4 I have the old Pocketwizard Plus, sadly I only have 1 transmitter and 1 receiver. I need to ideally add 3 more Plus II transceivers, but what I do right now is trigger my 580exII with the pocketwizard and it triggers my Vivitar 285HV and both my White Lightning x1600s via optical slaves. Primitive setup, but works 90+% of the time. -Abram-
Dec 11, 2009 02:39 | #5 agphotography wrote in post #9175597 I have the old Pocketwizard Plus, sadly I only have 1 transmitter and 1 receiver. I need to ideally add 3 more Plus II transceivers, but what I do right now is trigger my 580exII with the pocketwizard and it triggers my Vivitar 285HV and both my White Lightning x1600s via optical slaves. Primitive setup, but works 90+% of the time. I haven't considered any other brands of lights, but if I had Elinchrom lights I would definitely be shooting skyports. That system is so seamless with their new BXRi lights.
melvinudawl Senior Member 324 posts Joined Jan 2009 Location: Windsor, CT More info | Dec 11, 2009 02:39 | #6 My understanding is that the RF-602's(and cybersyncs) support manual flash only. If you want ETTL, then PW's are the way to go. I have a good luck with my 602's so far, but that is with the flashes in manual mode. And the 602's don't quite have the build quality of a PW, but at 10% the price, you can't beat them for manual flash triggering. 1D3 | 7D | 16-35II | 17-40 f/4L | 24-105 f/4L IS | 50 f/1.4 | 70-200f/2.8L | 70-200 f/4 | 85 f/1.8 | 100 f/2.8 Macro | 100-400 f/4.5-5.6L | 580EXII
Dec 11, 2009 02:47 | #7 melvinudawl wrote in post #9175646 My understanding is that the RF-602's(and cybersyncs) support manual flash only. If you want ETTL, then PW's are the way to go. I have a good luck with my 602's so far, but that is with the flashes in manual mode. And the 602's don't quite have the build quality of a PW, but at 10% the price, you can't beat them for manual flash triggering. Good luck!
melvinudawl Senior Member 324 posts Joined Jan 2009 Location: Windsor, CT More info | Dec 11, 2009 02:55 | #8 drdiesel1 wrote in post #9175661 Only the new PW Mini TT1 and FlexTT5 set are capable of TTL http://www.pocketwizard.com …mitter_receiver/36/TT1-C/ I'm just learning OCF, so the 602's were a cheap way to go, they trigger very reliably, but do you find that you use TTL often with the PW's? 1D3 | 7D | 16-35II | 17-40 f/4L | 24-105 f/4L IS | 50 f/1.4 | 70-200f/2.8L | 70-200 f/4 | 85 f/1.8 | 100 f/2.8 Macro | 100-400 f/4.5-5.6L | 580EXII
Dec 11, 2009 04:24 | #9 melvinudawl wrote in post #9175679 I'm just learning OCF, so the 602's were a cheap way to go, they trigger very reliably, but do you find that you use TTL often with the PW's? I have a 7d so i can control the ratio between the flashes, have been looking to manual for my own learning purposes only. Thanks!
Dec 11, 2009 10:32 | #10 thanks for the ideas. think pwII's look like the way to go Canon 5DMKII w/grip // Canon 40D w/grip // 70-200mm f/2.8L IS // 16-35mm f/2.8L II // 50mm f/1.4 // 85mm f/1.8 // 430 EX ll
Dec 11, 2009 10:34 | #11 RyanM wrote in post #9177098 thanks for the ideas. think pwII's look like the way to go
twcombs Member 73 posts Joined Oct 2007 Location: Vestal NY More info | Dec 11, 2009 22:07 | #12 I'm sure PWII's are good but I'm surprised no one mentioned Radiopopper JrX's. While more expensive than the 602's they're great triggers. Tim
Mystwalker Senior Member 608 posts Joined Feb 2008 More info | Are the Radiopoppers, Cybersyncs, etc ... more reliable then the "YongNuo (sp?)" or Cactus from EBay?
Dec 13, 2009 00:07 | #14 Mystwalker wrote in post #9186520 Are the Radiopoppers, Cybersyncs, etc ... more reliable then the "YongNuo (sp?)" or Cactus from EBay? I've been playing with old Cactus which have been working well for me - I shoot indoors (controlled environment) so range and interference probably not as big a problem. Am looking into the PW Mini/Flex because would like ETTL off camera - ~$200+ each is pretty expensive for a hobby ![]()
TeamSpeed 01010100 01010011 More info | Dec 13, 2009 06:40 | #15 Another option is the Phottix Tetra PT-04 II... Past Equipment | My Personal Gallery
| Latest registered member is Marcsaa 640 guests, 122 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
