Just received my Samsung 213T LCD monitor and connected it via the DVI output. I also have a Spyder 2 for calibration. I know the LCD monitor has menu adjustments for R, G and B but running the calibration software it asks you to adjust these values. I accessed the LCD menu but the R,G and B adjustments are grayed out not allowing adjustment. Is this a DVI thing as I think you can adjust them when using the analog interface? If so, what is the best way to run the calibration software allowing maximum adjustment of parameters? Appreciate advice from anyone who has calibrated a 213T or similar series LCD monitor.
Many Thanks,
