So I've had the M20 for several months, and it's worked flawlessly. Tonight I set it up in my living room to shoot the Christmas tree lights. I loosened the tension knob, moved the ballhead into the vertical notch for the camera's portrait orientation, and tightened the knob the same as I've done for months. When I was done shooting, I wanted to loosen the tension knob, and I couldn't budge it. I realized the ballhead itself was totally loose, as if the tension knob was loosened all the way...but the knob itself won't rotate in either direction, and I tried with all my strength. Is there some sort of lock on the knob that I don't know about? Or did I accidently overtighten the knob and break something inside? I emailed Markins to ask the same question but haven't heard back yet. I'm wondering if anyone has run into something similar with any of the Markins ballheads. I figure they're all the same in this regard. Thanks.
